Offline Lev.Sever
#1 Posted : 18 March 2024 23:39:27(UTC)
Lev.Sever
Slovenia
Hi all, allow me to rant.
I bought a used br118. Originally it should contain an older type of MM digital decoder - as far the scribbling on the loco instructions told me - but I was pleasantly surprised that it has a plug-in MFX decoder. Cool. Test it on analogue, and it deives smoothly and silently. Great. Then I try digital on my MS2. fails to find a locomotive. Weird. I try it again. Same. And again. This time it finds a MM 156 address. Ok? I try to operate it. Nothing. No response whatsoever. Try it on analogue yet again. Works. Digital attempt. Nothing. What is going on? Thanks.
thanks 1 user liked this useful post by Lev.Sever
#2 Posted : 19 March 2024 00:32:07(UTC)
Welcome Lev. This doesn't figure to me either.
#3 Posted : 19 March 2024 00:59:42(UTC)
From what I can figure out, this AC model 2001-2004 should have a 8-pin LMD Decoder. Ex-Factory, the model should have an address of 03 and it should be detectable as DCC or MM.
It was not a mfx decoder.
If the original owner changed the address, it would no longer be as described in the instructions.
MM (Maerklin-Motorola) addresses can be between 00 and 80 so 156 makes no sense unless this is the DCC address chosen by the original owner.
Try manually adding a DCC locomotive with address "03" and see if it works
If you can, please post a photo of the decoder/inside of the loco.
Offline Lev.Sever
#4 Posted : 19 March 2024 07:24:08(UTC)
Lev.Sever
Slovenia
Thanks. Will post a pic. Id did add itself as "MM-156". But it did not respond to anything. Tried manually. Tried a "loco reset" tried "DCC-3".nothing. It is a thumbnail sized smaller decoder with a "MFX" written on it. I also seen "ZIMO 30" scribbling somewhere. Should I call a fuy that has that test rail hooked on a PC? This has never happened before in my experience.
P.s.: it says
ATMFI
something
Somerhing
Taiwan-z
Numbers
Numbers
On the main chip, and on the plastic cover:
LP V33
MFX
#5 Posted : 19 March 2024 09:07:51(UTC)
LP V33
MFX
LP could stand for ESU LokPilot. Does it have a blue PCB? A photo might help.
Reminder: MM addresses can be in the range 1 to 255.
The MS2 cannot read the MM address, it just tests all addresses from 1 to 255 and looks for a response, but the failure rate is considerably high.
If the decoder supports mfx, it will ignore the MM address as long as the MS2 has mfx activated.
It could be worth a try to run loco detection again with only MM activated in the MS2.
Offline Lev.Sever
#6 Posted : 19 March 2024 10:28:37(UTC)
Lev.Sever
Slovenia
Hi, I will try to play with the MS2 settings a bit. I am writing this from my phone ATM., so I can't insert pics. I know that the locomotive should detect itself after being put on rails.
I haven't altered the MS2 settings before, and I do run my MM, multi-protocol, and DCC only locos with no issues.
#7 Posted : 19 March 2024 10:52:15(UTC)
Looks like an ESU decoder on the picture.
On early mfx decoders, sometimes the mfx sender fails, leaving you in a dead lock. The loco "talks" to the controller, but without operational sender on the decoder, the controller cannot register the loco.
The decoder should support the MM protocol, but only if mfx is disabled in the MS2.
Maybe time for a decoder upgrade.
Offline Lev.Sever
#8 Posted : 19 March 2024 11:27:56(UTC)
Lev.Sever
Slovenia
Well, if everything else fails, I will pop in the ESU 59020. Will try to disable the MFX on my MS2 later.
Offline Lev.Sever
#9 Posted : 20 March 2024 07:19:14(UTC)
Lev.Sever
Slovenia
SOLVED!
I disabled the MFX detection while registring the loco. Now it works.
#10 Posted : 20 March 2024 08:29:38(UTC)
SOLVED!
Even if you have mfx protocol enable in the MS2 it shouldn´t stop Roco locomotive if you use DCC protocol too.
I am pretty sure there are bugs in the MS2.
What software version do you have in the MS2?
This page was generated in 0.627 seconds.
