Offline fossie
#1 Posted : 17 March 2024 21:19:34(UTC)
fossie
Dear all
I have an old analogue Marklin HO 3013 BR1100 NS electric locomotive that is dead after being in storage for 5 years. The reverser mechanism moves and hums when reverse current is applied by the transformer....but the lights don't flash. I believe no voltage is going to the motor..... but I am unsure how to test this. I have replaced the brushes and cleaned the slider and the wheels and oiled the motor. Does anyone have a wiring diagram of this locomotive. On another note can this locomotive be converted to digital.IMG_7895.jpegIMG_7894.jpeg
Many thanks
Andy
Online JohnjeanB
#2 Posted : 17 March 2024 22:52:55(UTC)
Hi Andy
I like those locos and mine is a 3013 from 1957. There are indestructible
Here is the wiring diagram that I modified to include the directional lighting (in blue and red)
The diagrams is owned by https://www.toottoot.co.nz/
Since in your case the relay switches over but no lights and no motor, one possibility is the drum of the relay is not connected to ground but the relay is.
Here is the "wippenrelais" used on your loco (left side of page)
Note that the drum has a screw to connect it to the axle and to the frame ground (see lower left of picture)
Other possible cause is a broken wire somewhere
Cheers & good luck with your repair
#3 Posted : 18 March 2024 00:57:27(UTC)
Jean has given you excellent information to debug your running problem.
As to converting the loco to digital, this is certainly possible. To do so will need a decoder kit and a motor kit. I'm not sure exactly which motor kit is recommended for this loco.
Great loco you have there.
#4 Posted : 18 March 2024 01:58:02(UTC)
I have one of these. Does your's have the manual trigger for direction change? It should work as follows. Forward, Stop (with lights), Reverse, Stop (with lights), Forward... etc
In the meantime, try using the manual reverse tab to see if it changes anything. The relay may be stuck and using the manual knob may unblock it
Offline TrainIride
#5 Posted : 18 March 2024 08:08:47(UTC)
TrainIride
Agree with Jean,
this loco will never die.
you can check also this point :
This is the plate that brings current to the light bulbs.
Seems very twisted and can create a short circuit with the metal chassis.
Best Regards
Joël
Offline kaav800
#6 Posted : 18 March 2024 09:25:14(UTC)
kaav800
Hello Andy !
The problem may be on the directionswitch.It loks that the contactplate on top is bent up and therfor no contact for the motor.This is a common problem ,but it can be a problem to adjust it correct again.
You must be very careful by doing it,this thin metal will easily break.Maybe that this is the problem here.This contact is driven by the switch arm that goes in and out and lift the
contact arm (in center) on and off.Its this arm that is bent up.This solution was made for smother change of direction.
Best of luck kaav800
thanks 1 user liked this useful post by kaav800
Offline fossie
#7 Posted : 19 March 2024 05:11:57(UTC)
fossie
Dear All
Just an update.... I found two issues....
1) The copper brush did not have good contact with the motor drum..... replacing the brush fixed the problem.
2) The contact plate was bent on top of the reverser mechanism. If pressure is applied downwards on the plate contact is made and the locomotive moves and works. At the moment I am trying to fiddle/bend it to get it to work all the time. It is quiet tricky to do. Can you purchase another contact plate or is it a new reverser mechanism?.
Many thanks for your continuing help on this problem.
Andy
Offline kaav800
#8 Posted : 19 March 2024 09:01:17(UTC)
kaav800
hi again !!
Have a videolink here.Late in this movie there is a switch like yours,it dosent show any adjustment for the part witch is bent,but maybe you can se how it should be here.
https://www.google.com/s...db2,vid:T1F7J6CS55g,st:0 There is a knob on the arm that goes in and out that should lift the contactplate up when changing direction. Hope it can help Smile
Offline fossie
#9 Posted : 19 March 2024 22:30:37(UTC)
fossie
Thanks for the video.... That was perfect and the model is now working fine....
Thanks again for everybody's help.
Andy
thanks 1 user liked this useful post by fossie
This page was generated in 0.569 seconds.
