Offline Peterjs
#1 Posted : 12 March 2024 08:15:41(UTC)
Peterjs
Hello forum members, this is my first post.
I am setting up a Marklin C-track layout and have recently purchased some Marklin LED station lamps (article 72810).
I can get these to work on 16V AC (with flicker) but they're supposed to be OK with 12V DC but they don't work for me.
Do I need to solder a resistor to one of the wires? I'm sure the answer is somewhere in this forum, but if someone could point me in the right direction that would be great....thanks.
thanks 2 users liked this useful post by Peterjs
Online JohnjeanB
#2 Posted : 12 March 2024 11:10:46(UTC)
Hi Peter
A warm welcome to our great community.
Here a fervent Märklinist HO digital from Ile de France (near Paris)
Here is a glimpse of my C-Track layout
I don't have any Märklin recent LED lamp units. They use LED (of course sorry) and include a resistor.
If powered with DC source it will not work unless the polarity is right.
A 16 VAC LED should work with 12VAC but only less luminous.
Adding a resistor will reduce the current and dimm further the brigthness so not a good idea
When using 16 VAC a rectifier bridge (4 diodes) and a capacitor will remove any flickering but you may have to include a resistor in series to reduce the current.
16 VAC when rectified gives 22.6 VDC so a resistor of 560 Ohm or 1 kOhm in series could help.
I hope to see your project sometimes
Edited by user 12 March 2024 19:43:02(UTC)  | Reason: Not specified
Offline Peterjs
#3 Posted : 14 March 2024 09:16:01(UTC)
Peterjs
Hi Jean and thanks for your welcome & detailed advice.
I like the video of your excellent C-track layout, you've certainly got the lighting on the platforms well worked out!
Your mention of polarity solved the problem with my Marklin LEDs. I had been following the same yellow/brown protocol as my Faller lights, but I reversed that et voilà!
This page was generated in 0.365 seconds.
