Offline JordanG1
#1 Posted : 06 March 2024 20:27:15(UTC)
JordanG1
Hello! I recently purchased a Spur 1 5713 and it looks gorgeous. i believe it is AC, however. I Hear people are saying to use Diodes to convert to DC? I Can do diodes if needed but have no clue on how. i do not use DCC controls, only DC. if someone could please assist me on either, Thank you! i would rather not buy a decoder.
Offline RudiC
#2 Posted : 08 March 2024 19:35:00(UTC)
RudiC
I'd be quite surprised if this loco were using AC at all. I've seen an advertising (in German) for this loco stating it is DC. Try applying a small DC voltage across the wheels. Do they spin in the opposite direction if the voltage is reversed?
Edited by user 03 April 2024 22:36:22(UTC)  | Reason: Not specified
#3 Posted : 08 March 2024 23:53:55(UTC)
The loco is AC - but will run on DC as it is, since the "Allstrom" motor can run on DC too, you just can't reverse the loco Blink
The diode conversion is described here; after doing that you can reverse the loco by reversing your DC polarity:
https://www.marklin-user...digital/DILE900conv.html
This page was generated in 0.568 seconds.
