Offline PittsburghTim
#1 Posted : 08 March 2024 02:23:02(UTC)
PittsburghTim
I have long been interested in Marklin Trains since I was a young child and would watch the trains run in the window of AB Charles and Son Hobby Shop in the Dormont section of Pittsburgh. I got the bug to build a layout and have amassed a collection of building kits, a Marklin Digital starter set, and several C-track extension kits. While I am building and weathering the kits and mulling over track plans and layout ideas, I would like to purchase some additional locomotives and cars from different eras of production and have questions on compatibility.
Will cars made in the 60s, 70, and 80s couple with modern equipment? (Did the couplers change over time?)
If I want to run analog trains on a separate track oval, is it OK to run the trains with a vintage power pack or would it be better to purchase a more recent or current-production power pack?
What other brands of trains are compatible with Marklin trains?
There is only one shop in the area that carries Marklin and they are a general toy retailer, not a hobby shop. Rather than make lots of posts here, I was hoping that someone could recommend a website, book, or even a YouTube channel that would give me a decent overview of Marklin trains. Any help will be greatly appreciated.
Tim
thanks 2 users liked this useful post by PittsburghTim
Online marklinist5999
#2 Posted : 08 March 2024 12:06:49(UTC)
Welcome Tim. I've been into Marklin since 1990. I began with analog. Also a two rail d.c. 4X8 oval was my first layout. I bought a few Roco locomotives and still love those too. They make ac Marklin compatible ones also. You can run both digital and analog on separate tracks if course. Newer mfx, and DCC decoders are designed for the smp, or newer switched mode power supply. Conventional transformers can damage them, especially in a derailment or a short circuit.
The Marklin MS2, the CS3, and plus are multi protocol controllers for mfx, DCC, and the earlier Motorola format. They can operate Marklin,Trix, LGB, etc. The CS3s have a n integral powerful digital booster for a larger layout. The plus model includes a network cable jack for the S88 feedback modules used for automatic operations. This eliminates the need for a separate adapter and power supply for those.
By the way, I was born in Pittsburgh. I was just 6 when we moved here, but visited relatives twice annually through the 90s. We lived in Plum. My mother was from Midland. I still have cousins in Apollo, Brackenridge, Burrell, Plum, and one in Ambridge.
Since many dealers and shops are gone, most of us buy online from other states and even Germany. I have from AJC kids in Texas, Reynaulds in Illinois, Micro macro mundo in Miami Florida, Modellbahn Union shop in Kamen Germany, and Modellbahn shop Lippe in Detmold. Marklin has a US distribution center in Missouri. They have digital consultants Rick Sinclair and Curtis Jeng. Rick is also the Marklin employed repair specialist. They host periodic YouTube webinars which can all be viewed. There are several very good technical videos, but they are often in German. One who speaks good English is the model train fun guy. You will also learn a lot here from us members. You can also refer to the Marklin website for information about models, track, and accessories. There is so much to learn about making scenery and terrain as well. I must also mention a man Marklin of Sweden. He frequently posts on YouTube about many topics, in English. You can also find many in Instagram.
Edited by user 08 March 2024 20:18:37(UTC)  | Reason: Not specified
#3 Posted : 09 March 2024 00:52:56(UTC)
The older models (pre-1975) had older, slightly larger couplers made of metal, which in many cases were not isolated from the wheels (return).
Newer models have plastic couplers with metal hooks. They can ostensibly be used together, but I have found that the older couplers often interfere with the buffers on new models.
As far as transformers, I would recommend that you upgrade to a newer transformer if you have the older pre-1970s metal transformer (Dark blue) as the wiring has been known to deteriorate on the older ones. The light metal plastic ones and the current white ones should be ok although you may wish to pay attention as some were rated for 110VAC and others for 120VAC.
I got a new analog transformer from AJCKids a while back. It was taken from a start set.
Offline Unholz
#4 Posted : 09 March 2024 12:13:28(UTC)
Unholz
Many. ThumpUp With regard to the rolling stock attached to the locomotives (cars, vans, trucks - whatever you want to call them Smile ), almost everything goes, but you might have to change the couplers and/or the wheelsets. Mostly, this is not a real problem and requires only a few minutes of easy work.
As to the locomotives, many other brands offer items already converted for use on Marklin's AC/three rail system, or then you can either attempt to perform the task yourself or have it done by a specialized dealer or repair specialist, etc.
Digital is a field of its own. While most people will probably say that it saved the hobby, one can meanwhile also have the impression that it has made everything vastly more complicated and no longer enables beginners to simply plug in a transformer and turn the knob on it. Sad
This page was generated in 0.374 seconds.
