Offline jonas_sthlm
#1 Posted : 29 February 2024 15:11:35(UTC)
jonas_sthlm
webserver 2.5.2(6) 26.02.2024 **
cs3-gui 2.5.2(6)02.2024 **
lokicons 2.5.2 17.01.2024 **
spielewelt 2.5.2(0) 19.01.2024 **
candevices 2.5.2 22.02.2024 **
decoder FW V3.3.1.0/SpurN 09.02.2024 **
by translate.google.com
Version 2.5.2
Bug fixes
Improvements
Update Lokicons
Lokicons of the new products for 2024 have been added.
Bug fixes
S88 feedback for PC programs
The S88 feedback has been made functional. The background is an incorrect implementation of the CAN command. The correction was made incompatible with the PC programs. It could only be executed through the CS3.
Mfx third-party decoder registration and processing
When processing / registering / re-registering external mfx decoders, it could happen that this could not be completed and thus got stuck in an endless loop. For existing decoders, the message “The decoder has a changed firmware version and will be re-registered for security reasons” appears. However, this process could not be completed and so it kept coming back. Likewise, registering new decoders was not completely possible.
Newly created tractions
Newly created tractions could not be controlled. The cause of this has been resolved.
USB device detection
An error in reporting USB devices to the WebApp has been fixed so that the USB devices are now displayed correctly in the WebApp.
Incorrect display of booster consumption values
The booster consumption values were incorrectly interpreted by the web server, causing the web app to display the incorrect values.
Switch between WebApp and MobileWebApp
An error occurred while switching between the WebApp and MobileWebApp. Calling /app via mobile devices continued to point to /mobilewebapp. The bug in the browser switch has been fixed. Additionally, both apps tried to access the same browser cache, which caused the MobileWebApp to stop loading. This issue has also been resolved.
List of Lokicons in the file manager is empty
Previously, if there were corrupt Lokicons in the Lokicons folder, an empty list was returned. Now these icons are ignored and a list without these icons is returned.
Fixed error when resetting the locomotives
An error in the web server meant that the locomotive was not read out after a reset.
Fixed error in displaying events
Due to an error in interpreting the event data, only empty events were displayed.
Fixed error uploading Lokicons
JPEG and GIF files could not be uploaded because the file extension was not correctly changed to PNG.
Fixed an error when programming via the DecoderTool
An error in the web server meant that programming decoders via the DecoderTool was not possible.
thanks 4 users liked this useful post by jonas_sthlm
Offline jonas_sthlm
#2 Posted : 29 February 2024 15:31:52(UTC)
jonas_sthlm
It’s still a bugs with using ESU 5 decoder...
When putting a new engine, it read decoder but doesn't show it under the engine list.
Has the latest FW and it has never been on track before Huh
When I put back another engine it start reregistration that engine like a second one and CS3 after a minutes go into STOP mode OhMyGod
thanks 2 users liked this useful post by jonas_sthlm
Offline pa-pauls
#3 Posted : 29 February 2024 16:10:26(UTC)
pa-pauls
Looks like there is some bugs in the 2,5,2 (6) as well Blushing
I tried for the 3rd time with a USB Stick and still get the same error message as before,,, Good job Märklin Blushing
Think I go back to 2,4,1 software. It didn't have this problems
Go back to model trains they said, it is fun they said Flapper
Pål Paulsen
thanks 1 user liked this useful post by pa-pauls
Offline jonas_sthlm
#4 Posted : 29 February 2024 16:36:41(UTC)
jonas_sthlm
I removed all engines with ESU 5 decoder to avoid CS3 going into STOP mode.
It's getting ridiculous that M won't be able to handle this Mad
Offline pa-pauls
#5 Posted : 29 February 2024 17:31:40(UTC)
pa-pauls
Agreed !
Pål Paulsen
#6 Posted : 29 February 2024 17:42:57(UTC)
Why don´t you use DCC protocol instead with ESU loco?
#7 Posted : 29 February 2024 18:17:47(UTC)
Goofy, because ESU M4 decoders are mfx auto, and supposed to work with the CS3 like before. My JC sielbahn has an ESU M4 decoder and does.
Offline jonas_sthlm
#8 Posted : 29 February 2024 18:48:47(UTC)
jonas_sthlm
this is not science, so way should people start removing this settings?
Offline Diesel2000
#9 Posted : 29 February 2024 20:07:29(UTC)
Diesel2000
Version 2.5.2
Bug fixes
Improvements
Update Lokicons
Bug fixes
Reading this list of bug fixes it feels like there were A LOT of big problems with 2.5.1. It should never have been approved for release. I would hope they are improving their testing protocols.
thanks 2 users liked this useful post by Diesel2000
#10 Posted : 29 February 2024 20:21:12(UTC)
It´s a science because Märklin did put mfx, MM and DCC protocols in the system.
Offline jonas_sthlm
#11 Posted : 01 March 2024 11:32:31(UTC)
jonas_sthlm
It is a science if the do their own standard and doesn't understand it.. or if they don't bother to test the change before publish Mellow
Should we have to wait until next Christmas for an update again?
Offline jonas_sthlm
#12 Posted : 01 March 2024 11:44:04(UTC)
jonas_sthlm
Totally agree and I start to wonder if they has two isolated employees doing all testing.
I had expected that after two months they should minimum have resolved decoder issues.
Still broken links and missing information on the English page so they doesn't seems so important customers.
#13 Posted : 01 March 2024 12:34:21(UTC)
Probably so. Marklin doesn't employ a dedicated full time software engineer or department.
However, if they use well experienced consultants per diem, you would think they could be able to resolve this promptly. Unless they have to first look at the entire packet of data to analyze.
Offline jonas_sthlm
#14 Posted : 01 March 2024 13:11:45(UTC)
jonas_sthlm
They rename the link name to 2.5 instead 2.5.2 of the Update-Information CS 3 PDF, so that's maybe means no new information OhMyGod
#15 Posted : 01 March 2024 13:27:15(UTC)
A pdf is not code in a correct format. I'm not installing anything more for this unless I see a red dot when I connect my CS3 to the web.
Online JohnjeanB
#16 Posted : 01 March 2024 15:26:42(UTC)
Hi Jonas, Diesel
Marklinist here (all my equipment is Märklin except one LokSound 5 equipped loco.
I use V2.5.1(0) now for quite a while, with Rocrail and with my iPhone.
There are MANY things that are reported in the list of problem fixes that were VERY SPECIFIC and that I could not notice using Märklin locos with Märklin decoders.
The problem related to M88 is NONEXISTENT to me using with Rocrail.
What I am trying to say is: let's not exagerate on how bad V2.5.1(0) was.
To me: no problem with the ESU MFX usage
No problem with M88 handling of detectors for a PC (Rocrail)
The only bug I noticed (not in the list BTW) is the handling of the favourite loco list when using a smartphone (iPhone 11 in my case). No big deal, until fixed, have only one loco in the favourite list.
So, in conclusion Train modelers who like to mix brands a lot are more affected than pure Märklinists like me.
#17 Posted : 02 March 2024 09:44:47(UTC)
CS3/CS3+ is a base unit.
Offline jonas_sthlm
#18 Posted : 02 March 2024 14:07:25(UTC)
jonas_sthlm
yes, with their brilliant technical mfx function
#19 Posted : 02 March 2024 16:34:44(UTC)
Still people complain about mfx protocol.
#20 Posted : 02 March 2024 16:36:59(UTC)
Has anyone tried Zimo sound decoder type MSxxx?
Can you read it by use mfx protocol with latest CS3 version?
Offline gamolina
#21 Posted : 03 March 2024 14:31:44(UTC)
gamolina
Argentina
Hello Goofy! Last update has a firmware update for MFX. If your loco does not respond to your commands you must delete it and recognize again
Offline gamolina
#22 Posted : 03 March 2024 14:34:15(UTC)
gamolina
Argentina
Hello everybody, where can I find old versions of CS3 to download?
Because I always make the upgrade by ethernet connection.
Many thanks to all!
Offline franciscohg
#23 Posted : 03 March 2024 16:20:06(UTC)
franciscohg
Chile
Hello
In the marklin site, under service/cs3 updates , german version, you will find version 2.4.1 to download along with the instructions to downgrade
thanks 3 users liked this useful post by franciscohg
#24 Posted : 08 March 2024 13:48:55(UTC)
In another forum they are saying that latest upgraded version are now working without fail. Even ESU decoder works fine too.
#25 Posted : 10 March 2024 11:59:00(UTC)
I can´t find information about MS2 version 4.13.
What changed is there?
Offline jonas_sthlm
#26 Posted : 10 March 2024 19:24:02(UTC)
jonas_sthlm
someone works on sunday...
lokicons 2.5.2(1) 05.03.2024 **
#27 Posted : 17 March 2024 08:54:11(UTC)
There has been no update to the release notes
(other than to comment that the version 4.13 was available in the CAN package. The release note text themselves are for the prior release)
So it comes down to "observation" and I will note the appearance of the a Setting option ...
- called "Loco Symbol"
- with options for
- - Show
- - Hide.
This is seen with the 60653/7 Mobile Station but not the 60667 Mobile Station WLAN
Comment: it would be nice if they kept these "settings" (Display Brightness, Tacho Type, Loco Symbol) grouped together
rather than leaving "functions" (Factory defaults, Updates) in the middle of the list
I also observe a change in the icon graphics (may not have been the very latest release)
- e.g. the inertial "lead weight" icon is seen - whereas the MSW version is still showing the Tortoise
- The "Shunting function" icon does show the Tortoise coorcetly
I also observe that the MS retains its own/old Locos
(this may be a legacy issue of "same CS3, BUT not bothering to refresh the Loco Roster"
- i.e. Locos had been removed from CS3)
This page was generated in 0.824 seconds.
