Offline Alex H
#1 Posted : 14 February 2024 15:59:50(UTC)
Alex H
Hi. The yellow tracks in the images below are part offa small storage yard for small wagons. When looking at it, I feel that there should be an easier way to achieve this, especially on the bottom track - it seems to use so many very small pieces.
Am I being paranoid, or can someone suggest a better way?
Screenshot 2024-02-14 at 14.54.17.png (1,012kb) downloaded 299 time(s).
#2 Posted : 14 February 2024 22:24:17(UTC)
Two 24224 should take care of the curve, at least.
Offline Pasquiles
#3 Posted : 15 February 2024 00:02:35(UTC)
Pasquiles
Luxembourg
Agree
Offline Alex H
#4 Posted : 15 February 2024 08:48:11(UTC)
Alex H
Thanks both
#5 Posted : 15 February 2024 09:04:40(UTC)
24094+24077=24172. (Upper track)
Offline Alex H
#6 Posted : 15 February 2024 09:57:33(UTC)
Alex H
BigGrin BigGrin
Offline PacoM
#7 Posted : 26 February 2024 17:19:17(UTC)
PacoM
thanks 2 users liked this useful post by PacoM
Offline PacoM
#8 Posted : 26 February 2024 17:55:26(UTC)
PacoM
thanks 3 users liked this useful post by PacoM
Offline Copenhagen
#9 Posted : 27 February 2024 10:10:51(UTC)
Copenhagen
Two great solutions from PacoM above. Even if a bit more elegant I would caution the use of a three-way turnout. It can cause problems with some rolling stock in my experience.
Offline dickinsonj
#10 Posted : 28 February 2024 00:57:40(UTC)
I have four three-way turnouts and they do indeed cause me problems, sometimes even when set for straight and not turning. The worst offenders are the small two axle wagons that rock and roll as they pass through them, even at slow speeds. I have tried to figure out why but I have never come up with an answer.
Offline revmox
#11 Posted : 28 February 2024 04:16:40(UTC)
revmox
Some forum members cut standard Marklin track pieces to simplify or create a particular track configuration - it is quite easy to do - but others may see it as sacrilege.
Your original design then becomes much simpler and cheaper to achieve - especially with all those dead-end sidings. There are many posts available about how to do it. Done properly, no one will ever be able to tell.
Offline Copenhagen
#12 Posted : 28 February 2024 09:09:10(UTC)
Copenhagen
I only have one threeway switch. One general problem that also occurs with standard turnouts is wheel spacing adjustment. If the wagons have DC wheels they usually have to be adjusted to a smaller spacing.
Another problem can be with small locomotives that that lose connection and stop at some places (and at some speeds).
A third thing is the construction of the turnout tongues and the way they work. If the tongues don't move to their fullest extent it can lead to derailments in some directions.
#13 Posted : 29 February 2024 08:25:17(UTC)
Most probably because the design relies on the height/depth of the oversize Märklin flanges of the wheels. With more modern rolling stock, the wheels "fall into" the track. -As in; They dont really roll on top of the track, but runs on the top of the flanges on top of the track-bed (look for a metal insert in the "heart-pieces"(*).
(*); Herzstück in german... RollEyes
Offline Copenhagen
#14 Posted : 29 February 2024 09:25:50(UTC)
Copenhagen
To Henrik above: exactly and spot on. I have a double slip switch that I've had to modify with conductive paint and I have improved my threeway switch by gluing a thin strip of aluminum foil to it somewhere.
thanks 3 users liked this useful post by Copenhagen
C track geometry question (H0-scale)
by Mikael 01/01/2005 23:39:19(UTC)
This page was generated in 0.913 seconds.
