Offline einotuominen
#1 Posted : 20 February 2024 10:18:39(UTC)
einotuominen
I've been playing around with Rocrail's XML scripts a bit, but never used things like variables in them and so on.
Previously I've had a startup and shutdown scripts per loco. What the script does is that it turns on the engine, lights, etc etc. Shutdown is obviously the opposite.
Having a script per loco is a bit much as the action list quite quickly becomes very cluttered of stuff and it is hard to manage. Rocrails user interface is also like the UI that ADSL modems had back in the 90s... Bad and slow to use.
So the question is, how would I create single scripts where the loco in question would be passed as a variable?
In addition, since I have Märklin and ESU decoders, the function mappings differ a bit. For example on ESU the engine is at F8 while in Märklin it is at F2. This would mean that the XML script would need to have some way of identifying something of the loco and make a condition.
Having conditions for each individual loco would also suit me, but I'd just like to have everything in the same XML file.
How would this be achieved?
-Eino
Offline pederbc
#2 Posted : 20 February 2024 11:29:52(UTC)
pederbc
Hi Eino,
I’m using Traincontroller myself so I have no experience in Rocrail. But in Triancontroller you can create aliases of the functions. For example I can create a virtual function ”loksound”, and then on each loco assign a real function to this virtual function. Then in scripts etc use this virtual function instead. Very convenient. Can you check if this functionality exists in Rocrail as well? I have created virtual functions for lights, headlights, wagon lights, horns etc.
Peder
#3 Posted : 20 February 2024 12:01:09(UTC)
Hi Eino
Very interesting questions indeed and I am sorry not to know the answers.
Here is the little I think I know:
1- when creating an Action, to get an ACTION started, there is only a "Path" to be indicated but no space for parameter passing.
2- in an XML program one may define a VARIABLE that may be used by others (sort of PUBLIC variable) that anyone can read or update.
3- there is a possibility for an XML program to look into Rocrail's own registers, data tables, etc
I wrote some programs to look into Rocrail's data table for instance to know the occupation of a staging block or to know which locos were on the layout etc.
Closer to your needs I have a program to start the layout:
- locate the position of each loco
- decide to turn ON or OFF the lights and sound depending if the locos are on a route, in a shed or not on the layout at all. This is done by exploring Rocrail tables
- also configure the specific fonctions of cars
Here it is. It may help you create your own program.
Here ROCRAIL's table lclist is used to extract the position of each loco
0 AK Licht on V4.zip (2kb) downloaded 14 time(s).
There are many other Tables in Rocrail that may be of insterest to read & analyse (Block list, Staging block list, Tour list, Action list
Of course, you are not allowed to change values into Rocrail files because one information is written in multiple places and since you don't know the exhautive list, then better refrain from doing it.
Offline Martti Mäntylä
#4 Posted : 20 February 2024 12:16:14(UTC)
Martti Mäntylä
This is the XML macro I use:
Code:
[img]<?xml version="1.0" encoding="UTF-8"?>
<xmlscript>
    <fn id="%lcid%" fndesc="Lights" fncmd="on"/>
    <sleep time="2000"></sleep>
    <switch var="%lcid%">
        <case val="BR 103 137-6">
            <fn id="%lcid%" fndesc="Cockpit lights" fncmd="on"/>
            <fn id="%lcid%" fndesc="Front panto up" fncmd="on"/>
        </case>
        <case val="BR 01 147 H">
            <fn id="%lcid%" fndesc="Steam machine" fncmd="on"/>
            <sleep time="200"></sleep>
            <fn id="%lcid%" fndesc="Firepit" fncmd="on"/>
            <fn id="%lcid%" fndesc="Smoke" fncmd="on"/>
            <sleep time="2600"></sleep>
        </case>
    </switch>
</xmlscript>[/img]
The macro is executed by an event associated with the "depart" state change of a block. The variable "%lcid%" contains the identifier of the locomotive currently in that block. The function names are the ones used in the locomotive description ("Functions" tab).
The trick is to figure out which preset variables are available from Rocrail. Rocrail documentation keeps this information well hidden, but the page https://wiki.rocrail.net/doku.ph...alling&s%5B%5D=block gives some hints. You can also pass parameters to macros if needed.
- Martti M.
#5 Posted : 20 February 2024 13:17:00(UTC)
Martti Mäntylä
I must expand my reply regarding parameter passing to XML, because it is fairly unobvious.
The parameters (separated by commas) to be passed must be given in the action control definition, see https://wiki.rocrail.net/doku.ph...=actionctrl-en#parameter. The "parameter" field in the action itself (https://wiki.rocrail.net/doku.php?id=actions-en) is used for other purposes.
In the XML macro, the given parameters are available as "%param1%, %param2%, ...".
Just like Jean said, one can also pull information from Rocrail tables, such as
Code:
<query vr="lcid" table="bklist" id="Asema_2b" get="locid"/>
for getting the identifier of the loco currently occupying a certain block.
- Martti M.
#6 Posted : 20 February 2024 13:27:00(UTC)
einotuominen
Thanks!
Where exactly in the block details this action is to be associated with the depart? Obviously what I'd write to the param field in this dialog: https://wiki.rocrail.net...=actionctrl-en#parameter would simply be %lcid% ?
So the whole thing would be dynamic then? Everytime a loco departs the block that triggers this action the script is run and the loco id is passed to the script in the variable %lcid% ?
-Eino
thanks 1 user liked this useful post by einotuominen
#7 Posted : 20 February 2024 13:29:51(UTC)
einotuominen
Thanks Jean, this XML of your's has got great examples for a lot of purposes!
Can't wait to start scripting/automating my new layout... (can't wait do the scenery as well... Endless work list... angry wife BigGrin )
-Eino
#8 Posted : 20 February 2024 13:38:40(UTC)
Martti Mäntylä
Like this:
There is no need to place the %lcid% as a parameter, it is an automatically set Rocrail variable available in many (but not all, the details confuse me too) cases. The "locomotive" field is filled by Rocrail, no need to touch it.
Yes, the whole thing is automatic. Whenever a loco leaves the block (and launches the "depart" event by doing so), the action control causes the action to take place and the XML macro is run. The identity of the departing loco is available in the Rocrail variable %lcid%.
- Martti M.
#9 Posted : 20 February 2024 14:09:38(UTC)
einotuominen
Like this:
Got it. Thanks. Yes it's a bit confusing that there is a locomotive drop down there and it has a value selected too.
-Eino
This page was generated in 0.516 seconds.
