Offline LeoArietis
#1 Posted : 09 February 2024 11:16:49(UTC)
LeoArietis
I have several C-track Märklin 24624 switches (double slip), and I've noticed that the motors frequently struggle to fully switch them to the end position, resulting in the tongues not being securely fixed in place. As a consequence, the tongues can slide out from the rail, leading to derailments.
Do you have any suggestions for alternative motors or drives to address this issue?
Additionally, the rods responsible for controlling and moving the tongues beneath the track bed are not rigid enough. The entire mechanism seems overly delicate and lacks room for error.
Current layout:
The former project:
#2 Posted : 09 February 2024 11:40:58(UTC)
Leo, have you tried cleaning the top of the mechanism with compressed air and applying silicone lubricant at the pivots and actuator? It has helped a couple of my single turnouts.
#3 Posted : 09 February 2024 12:04:15(UTC)
I wouldnt use any greasy/liquid lubricant on points!
I use graphite. You can scrape it off a pencil, if you dont have anything else.
#4 Posted : 09 February 2024 13:29:39(UTC)
I use a very light synthetic oil made for Saxaphones. No residue to collect dust.
Offline rhfil
#5 Posted : 09 February 2024 13:33:27(UTC)
rhfil
Graphite, a great lubricant, is electrically conductive so I would not use it anyplace that might carry current. I use it only in places where dust and dirt could accumulate on any parts - cylinder locks as an example. Silicone lubricant should dry up pretty quickly. I use it where plastic rubs against plastic above the track like in bogies or couplers. Teflon lubricant is really good but usually only available in spray so can not be controlled easily. You can spray it on something like a sheet of paper and then use a brush to apply it to small areas. The silicone avoids that need.
Offline PeFu
#6 Posted : 09 February 2024 16:47:39(UTC)
PeFu
Have a look on this old thread on the same topic.
Smile
This page was generated in 0.386 seconds.
