#1 Posted : 30 December 2023 02:28:20(UTC)
I am happy to be able to report that I have finally seen photos of both sides of the model, showing both the cab with the pantograph and the one without.
My first question that has now been answered is whether the model is equipped with a destination sign in both cabs.
The answer to that appears to be YES.
This makes me very happy as the model can be run in either direction. The ebay photo also shows both sides outfitted with HO couplers. Some of the Re 4/4II models came with one end already fitted with a closed front skirt.
I never checked to see whether the actual locomotives have these destination signs on both sides. It would seem that, for example, on the run to Chur and back that one cab might say Zürich HB and the other might say Chur, In a push-pull consist, only one destination sign would be required, on the lead end of the locomotive, with the other sign being in the pilot coach. Hopefully one of our Swiss experts can elaborate on this.
The second question concerns the Swiss Pleitegeier logo (that's a lot of "e"s). I had noticed on my earlier 69842 and 62690 that there was a cut out where the logo symbol was set into the locomotive shell. I was hoping that the new model would have this more flush, but they have once again used the same design. The good news is that the ebay photos do not look as ill-fitting as some of the official Roco ones do.
I am going to have to adjust the roof wiring so that the wire leads from the air blast circuit breaker to the pantograph. In many of the photos, this seems slightly out of position. It should slide a little in the direction of the pantograph with a little manipulation.
https://www.roco.cc/resp...Mnw3NTAwMDAyLWQ1LmpwZw==
The ebay photos can be found here: https://www.ebay.com/itm/386517781668?
I guess that my lok will arrive at my dealer sometime within the next month.
#2 Posted : 01 January 2024 03:23:05(UTC)
I'm going to have to pick one up... I had a HAG example I loved, but not enough detail for me. This one ticks all the boxes...
#3 Posted : 01 January 2024 12:28:38(UTC)
Roco detailing is super. Small add on parts can fall off and get lost. Marklin has also done a great job on detailing on the newer re 4/4 and re 420.
#4 Posted : 02 January 2024 04:03:27(UTC)
I have not had any parts fall of any of my Roco Re 4/4IIs. The Roco models are 2000/2010s tech. The Maerklin models were 1990s tech.
I have a lot of those too.
The Roco models have much better sound and detail.
One more detail... Maerklin has never made a model of the first series of the Re 4/4II. To date, the only models have come from Hag (Old Generation), Lima/Rivarossi and Roco.
#5 Posted : 12 January 2024 06:54:17(UTC)
I had a chance over the past few days to do a lot of catching up and I have been dismayed by some of the posts about the new Roco Re 420 (Re 4/4II) on Drehscheibe and Stummi Forums:
https://www.stummiforum....xpress-erste-Bilder.html
https://www.drehscheibe-...en/read.php?010,10673214
It seems as though there is a significant problem with the rendering of the model.
One of the posts describe how the two hand rails on the side of the roof are incorrectly positioned. Another post goes on to mention that the battery compartment (the box which sits between the bogies) is inverted. The author describes how he had to modify the locomotive shell to get the shell to sit properly in the opposition direction with the battery compartments properly aligned. I presume that the battery compartment is a part which can be detached, but I am not certain it can be mounted in the other direction.
Thinking about these two issues, it occurred to me that both are symptoms of the same mistake. Neither part is falsely positioned. Where somebody at Roco made a mistake is that the pantograph and the roof details were added to the wrong side of the model during the design process or during the mould making process. I don't know how this affects the power feed from the pantograph to the PC board (if this exists).
In my opinion, the only way to correct this flaw would be for Roco to replace the shells for all customers who have ordered this model, so that all the details appear as they should per prototype.
Would this be a deal killer for you or would you accept it as is and just run it, even though it is visibly "off" from all of the other Re 4/4s that Roco has made?
I have contacted Roco and I wait to see how they respond. I was really really looking forward to this model but I'm kind of asking myself whether it is worth the $450-500 at this point?
The original mockup of the model as it appeared on the AJCKids site in early 2023: https://ajckids.com/cdn/...02_580x.jpg?v=1673370744
The model as it appears at release (Roco): https://www.roco.cc/rde/...8-swiss-express-sbb.html
You can see the AJC image with my comments here: Roco-7520002_580x Comments.jpg
For those who want to dismiss this as "Nietenzahler" nonsense (Nitpicking), I just want my models to match and for a model that costs 100% more than the older versions, I expect better.
For comparison, here are my 69842 and 68690 models (68690 is the version with a single arm pantograph):
63842/68342 (11141)
62690/68690 (11108)
Offline Unholz
#6 Posted : 12 January 2024 11:34:21(UTC)
Unholz
Well, on the Stummi forum a crazy guy actually cut off those two small handrails on the sloping side of the roof and inserted them on the other side. The result looks absolutely horrible/ridiculous, but the man actually stated that he will cover the original position of the two things with airbrush paint. Cursing Blink It's not difficult to imagine how that will finally look.
In such a case, I definitely prefer to be regarded as a non-nitpicker than having to look at a distorted and thus worthless "model".
#7 Posted : 12 January 2024 17:31:14(UTC)
I have had a few dealings with that person and respect them on that basis, as I do you for the assistance you have afforded me in prior instances as well.
I admire the fact that he decided to try to correct the flaws himself, but for a new model that costs EUR 400, I would not want to do all kinds of kitbashing myself
and would probably tend to avoid the model. However, in the case of a model that is greatly anticipated, such cases should be dealt with as manufacturing defects.
Roco's website leads to this: https://www.roco.cc/ren/...I-complain-about-an-item
https://www.roco.cc/rde/...inen-artikel-reklamieren
If you try to address such a situation with a dealer, the most likely response will be along the lines of:
"Do you want it or not?" because dealers have other concerns other than acting as your intermediary with the manufacturer.
It is a shame that manufacturers have decided on attitudes like this, but at least ESU is probably not feeling as bad about the Ae 6/6 as they were a month ago 🤣🤬
Online David Dewar
#8 Posted : 13 January 2024 21:44:34(UTC)
Mike you asked If a deal killer. I have never seen any of the models I have in real form and for me I look for good running and reliability. Providing a door handle is beside a door that that is OK.
Regarding the current cost of models I beleive they are way to high for what is really just a toy train which looks like the original.
I understand your view but doubt the manufacturer will take much notice as long as their models sell.
#9 Posted : 14 January 2024 19:00:55(UTC)
Some manufacturers seem to have a policy of "laissez faire" when it comes to dealing with design or rendering flaws in production.
Roco, however, seems to have been more proactive. For example, the SBB Re 4/4II "Bourret" had some issues with the paintwork and the models were recalled or Roco replaced the loco shell for it's customers. A similar example would be when LS Models issued replacement shells for some SBB coaches where the rain gutters were omitted on one side of the model.
This type of service has a cost, but in terms of making the clientele feel that the company cares about them, it goes a long way.
I have had a few Roco models where there were issues with light shining through the loco shell. In each case, the matter was remedied by the factory or by the dealer.
I had a few similar cases with other companies and was left to find my own solution. I am usually adverse to tampering with models while they are under warranty.
I hope that Roco will find a "Bourret" type solution to remedy this situation.
#10 Posted : 16 January 2024 02:18:32(UTC)
There are three new models of the Re 4/4II First Series announced for 2024, a green one (11127), a green one (11131) and a BLS one (420 501) (ex-11110).
I would hope that Roco would make sure that these models had the correct details and that in the process, owners of the Swiss Express version would receive replacement shells.
#11 Posted : 17 January 2024 04:20:36(UTC)
In the Swiss Hag Forum, one member stated that he received a reply from Roco about the Re 4/4II Swiss Express
Leider ist es während der Produktion zu Problem mit den Spritzgusswerkzeugen gekommen, welche für die Positionierung der Löcher für die Handgriffe notwendig sind. Der dadurch entstandene Fehler ist erst bei einer späteren Qualitätskontrolle festgestellt worden, als bereits ein Großteil der Modelle in Auslieferung und auf dem Versandweg war.
Wir möchten uns für dieses fehlerhafte Detail ausdrücklich entschuldigen! Für ROCO gilt für alle Produkte ein hoher Qualitätsanspruch, der fordert, dass Modelle möglichst detailliert und vorbildgerecht produziert und ausgeliefert werden.
Daher wurden unverzüglich Maßnahmen ergriffen, damit für alle weiteren Modelle der Elektrolokomotive Re 4/4, welche in den nächsten Jahren als Neuheit folgen, die Handgriffe wie erforderlich montiert werden können.
Der fehlende Rückspiegel wird derzeit nachproduziert und allen Vertriebspartnern kostenlos automatisch zugeschickt.
They apologize for the mistake. They are taking steps to ensure that the hand rails will be corrected for future models to be released in 2024 and beyond.
As far as any remedy for the current model, the missing rear view mirror will be sent to all dealers, but no action is announced for the problems with the locomotive shell.
Not acceptable. As it stands, my order is likely to be cancelled.
Offline Unholz
#12 Posted : 17 January 2024 15:23:33(UTC)
Unholz
Sorry for my strong words, but to demand some kind of withdrawal of the model or the replacement of the body shell because of the handrail trifle shows IMHO a derailed sense of reality and also has no legal basis. From an objective point of view, the locomotive simply has no relevant defect.
Perhaps it wouldn't be a bad idea if all too narrow-minded nit-pickers (general expression, no one is being addressed personally...) attended a guest lecture in economics and law before making a huge fuss in the relevant forums. As you have cited above, the manufacturer has already commented on their further course of action. So there is no point in lamenting in forums any longer. Just cancel your order, and that's that. Other customers will happily grab their opportunity.
Regards, Stefan
#13 Posted : 17 January 2024 17:16:09(UTC)
Outwardly, it may appear to be a simple issue of four little handrails that were drilled and mounted in the false position, but when you take a closer look at the model, the flaw is more serious.
The flaw is actually that somewhere during design/production, the pantograph and other roof details were applied to the model in an inverted direction. The result is the following:
1) Handrails on roof appear on the wrong side of the center vent
2) Battery compartments on chassis frame are inverted vis-a-vis the prototype
Without addressing anybody personally, I seem to remember some people critical of comments/reviews on this model were going on about a recent ESU model for a minor flaw in design/production of that model.
Online David Dewar
#14 Posted : 17 January 2024 17:40:56(UTC)
I doubt we would ever get a model that looks exactly like the original and how many would even know exactly what the original looked liked. It is possible that all the locos I own may not be as the actual loco but for me they look fine and run well. If I ever had any complaints It would be with coaches which for the cost we should should be made of slightly stronger plastic and the ability open the roof easily and with a heavier metal weight. The detail underneath in my view is not required as is not seen. Maybe a bit off track here with the post but basically we do not need an exact replica of the original.
Although the cost of a loco is now quite high much of this is profit for the manufacturer and dealer which they require to keep the hobby going.
#15 Posted : 17 January 2024 21:17:48(UTC)
David,
this model is the tenth or so model of this locomotive. The first was 63840, which was followed by 63841-45, 63847 (1/2 of Re 10/10 Set) and then 62690-91.
The prior nine models were correctly rendered. So, how is it that Roco flubbed a detail that they had right up until then?
Having been to Switzerland numerous times I have seen the prototype and I know what they look like. I have ten other models of the same locomotive type that this new model would be sitting next to on the layout or in my display, where the differences would still out like a sore thumb.
I don't expect it to be perfect. Merely to be as accurate as possible, meaning that small deviations for operational requirements are acceptable, but I expect the models to look as correct as possible. Especially when you consider that the original models around 2001 cost EUR 200 and today's models are over EUR 400.
Respectfully yours,
#16 Posted : 18 January 2024 08:13:19(UTC)
I have made my decision. I will be cancelling my order for the 7520002 Re 4/4II. I am going to try to find a Re 4/4III from the 79410 set instead. I already have two Swiss Express models, one representing the 80s and one from the 90s. I only have one Re 4/4III of the second series (11351-11370) and a second one would make a nice addition to my collection.
I am certain that at some point, Roco will release another Swiss Express locomotive to go with the LS Models EWIII coach set. We will see what happens then.
I may go for the newly announced (2024) Re 4/4II in red, as that one would look as good with a train from the same period as the 7520002.
Online David Dewar
#17 Posted : 18 January 2024 17:26:22(UTC)
David,
Respectfully yours,
Hi Mike. I do understand that with your knowledge of Swiss Locos and a collector of what must be a large number of locos and coaches you will look for as near to perfect detail as possible. I have three Swiss Locos along with coaches and a set of Marklin coaches on order to come and enjoy running them and they do look good but I have no idea as to how accurate they are.
I agree that the cost now is high and in many ways that has to be justified by the manufacturer.
Hopefully you will be able to obtain the model you are looking for in the future.
David
Offline Harryv40
#18 Posted : 19 January 2024 12:49:02(UTC)
Harryv40
I have read this discussion with interest and it in my opinion has raised a number of points
Firstly, individual opinions, you are correct that higher cost must be linked to better finish, it is important that parts are shown in the correct position. The flip side of that is we can all vote with our wallet, if we feel the quality of the finish does not match the price, then we don’t buy it!
Secondly, when locos are running on the layout then small detail errors are not seen, especially if like me your eyesite is ageing.
Thirdly, how we use our locos is Important, some people run there locos, coaches and wagons, other display them, if you display them any error are easier to spot.
Finally, it’s up to personal choice, I for one would not start cutting pieces off the body of the loco and destroying the appear of the model. Perhaps I would not buy!
But what we all must remember it is personal choice how we invest our money, but unfortunately you cannot always but perfection.
Harry
#19 Posted : 26 January 2024 06:18:46(UTC)
I received a surprise yesterday when Canada Post delivered a parcel. Inside the box was the 7520002 Re 4/4II Swiss Express. My dealer did not inform me that the item had arrived and so it left the West Coast on January 19th and arrived in Montreal on the 24th. I decided that I would keep it in the end. The total cost of the item was CAD$560 including tax and shipping. As I stated before, for that amount of money, I expect the manufacturer to fully conduct proper inspection of the production process, from the CAD work through to the final product. In addition, for production involving models where prior models of the same model exist, that the company have said model on hand for comparison to ensure that details match the prior editions.
When looking at the model on its own, the flaws do not seem significant. The handrails on the roof and the inverted battery case are minor when taken on their own.
When you look at the model closer, you notice a few more details of interest. The slider is on the bogie with no pantograph. On all of the prior models, the slider was situated on the bogie under the pantograph. This is the first model of a Re 4/4II (11106-11155) with a driver figure. I presume that the part was just mounted in the cab under the pantograph.
It is my opinion that these flaws are not separate, but rather an indicator of the true flaw.
Somewhere between the CAD design and the production of the diecast molds used to make the final shell, the roof details were inverted, meaning that the pantograph moved from cab 1 to cab 2 and the roof ventilators and wiring was rendered in the opposite direction. If you picture the pantograph as I describe, you will note that the position of the handrails and the direction of the battery compartment now appear correct. It also means that the slider would be correctly fitted to the bogie with the pantograph.
Here are my Swiss Express models (69842, 68690 and the new 7520002):
7520002
68690
The flaw becomes very noticeable when the locomotive is alongside other models of the same series and I just happen to have 10 other ones.
#20 Posted : 30 January 2024 19:10:58(UTC)
I came across this in a newsletter from a North American company:
We make dozens of different models per year, and while we try to learn as much as we can about the models we are making, we can't be experts on everything, but we don't mind being corrected. If you see anything wrong in our preliminary designs, please get in touch with us. You can use our new form by clicking here, or you can email umactually(at)rapidotrains.com.
See it. Say it. Sorted.
Because we'd like to get your "Um, actually" email before we make the models rather than after production is finished!
Jason
I love this. I would love to see companies like Roco and Maerklin emulate this, as they seem to be leaving quality control up to the customer in many cases these days.
At least, make it easier for us to report issues when we detect them...
This page was generated in 0.712 seconds.
