Offline BenP
#1 Posted : 15 January 2024 20:46:56(UTC)
BenP
This request perhaps sounds silly, but I need analog AC power to test some new eBay acquisitions, but have no access to my classic Marklin white transformers. Instead I have only Z-type 10V DC transformers and MS2 digital 18V AC power. The latter also has a variable 3-12V DC power supply.
Can I somehow use these available power supplies to run vintage AC locs? Reversing pulse is not needed. (I prefer not having unregulated full 18V power on test track).
Ben
Edited by user 21 January 2024 16:07:40(UTC)  | Reason: Not specified
Online marklinist5999
#2 Posted : 15 January 2024 22:34:52(UTC)
Ben, where are your 16 volts ac trafos? Don't invite trouble. DC current usually is safe for an ac motor. It may run faster, and draw more power.
Offline BenP
#3 Posted : 15 January 2024 22:45:23(UTC)
BenP
Thx; will try. HO layout is all packed and stored for upcoming move. I was not clever enough to bring an AC unit with me. Just a small Z layout at my current place, until I have space to rebuild.
#4 Posted : 16 January 2024 01:52:01(UTC)
You can get a straight 16VAC output from the AC leads on a lot of DC transformers.
To test an AC analog locomotive, you can also attach leads from a 9V battery to the wheels and slider
Hope this helps
#5 Posted : 16 January 2024 07:10:52(UTC)
Older H0 Märklin comes with an AC/DC motor, so running on DC is no issue.
Digital locos may not respond to DC because of the decoder, but analogue locos without decoder will work fine.
#6 Posted : 16 January 2024 07:12:23(UTC)
Why would a loco run faster on 16 V DC than it does on 16 V AC?
#7 Posted : 16 January 2024 13:21:42(UTC)
Because the DC current is steady without cycles. Cogging of the armature commutator is not measurable.
Offline BenP
#8 Posted : 21 January 2024 13:53:49(UTC)
BenP
Thx for the lesson. I did not realize that variable DC can power AC motors, so Märklin Z transformer solves the loc test needs I have ( it also has 10V AC accessories out).
Ben
#9 Posted : 21 January 2024 16:17:22(UTC)
If this power source is for powering the MS2 unit, you can use it together with some pairs (at least 3) of anti-parallel diodes, in series with the power.
For each pair of anti-parallel diodes the voltage drop is around 0,7V. The anti-parallel position of the diodes will allow the full AC wave to get to the track.
Offline BenP
#10 Posted : 21 January 2024 16:25:00(UTC)
BenP
Can you draw the arrangement for me. I am novice with this type of electrical.
Ben
#11 Posted : 23 January 2024 08:49:44(UTC)
Ben
Maybe this will explain it; (In the picture, it is the BOTTOM PART that shows what I am referring to)
https://ogrforum.ogaugerr.com/fileSendAction/fcType/0/fcOid/155434571115824528/filePointer/155434571147451112/fodoid/155434571147451106/imageType/LARGE/inlineImage/true/bridge%2520rectifier%2520as%2520two%2520pairs%2520of%2520diodes.jpg
This is the thread from where I found the pic;
https://ogrforum.ogaugerr.com/topic/voltage-drop-for-dispatch-board
#12 Posted : 23 January 2024 09:29:50(UTC)
With 16 V AC, the voltage floats between +22.6 V and -22.6 V to make it as efficient as 16 V DC.
Light bulbs are not brighter with 16 V DC than with 16 V AC.
Not much difference in speed to be expected with a Märklin AC/DC motor.
This page was generated in 0.480 seconds.
