Offline einotuominen
#1 Posted : 08 January 2024 14:34:09(UTC)
einotuominen
Hi guys,
Can I use the Märklin powerpack 66111 that comes with the white Märklin speed controller together with a Rokuhan RC02 PWM speed controller?
BR,
Eino
Offline husafreak
#2 Posted : 10 January 2024 04:43:26(UTC)
husafreak
I don't know the Marklin 66111 but proceed with caution. I do know that the Rokuhan wall wart puts out 1A at 12V and the plug barrel is 5.4mm outer diameter and center positive. If the barrel of your Marklin power pack seems to fit snugly and has the same center positive and similar specs it might work and probably it can do no damage. There should be a diagram on the Marklin wall wart or use a voltmeter.
#3 Posted : 10 January 2024 08:45:37(UTC)
einotuominen
Seemed to work fine!
-Eino
This page was generated in 0.197 seconds.
