Offline Markey
#1 Posted : 01 January 2024 21:46:02(UTC)
Markey
Ireland
I have the Marklin steam loco ref 39010 the wheels on the front pony truck are not turning right.Their is a brass strip going onto each wheel i just wonder has anyone got a diagram of what way the brass strip should be fitted properly.As the loco is running the front pony truck wheel isnt turning.
#2 Posted : 01 January 2024 23:03:08(UTC)
Hi Markey
The "front pony truck" is a bogie (just wanting to discuss the same thing.
It looks like this
It is held in place by one shouldered screw
A flat spring with 6 tongues ensure a ground return through the bogie (2 center ones pointed in red). 4 tongues ensure an appropriate pressure of the bogie on the rails(four external ones pointedf in blue).
If the bogie wheels dont rotate easily, then
- the bearings need cleaning and light lubrication
- the center tongues press too much on the axles
- the wheelset is partly disengaged from the bogie plastic chassis
This page was generated in 0.216 seconds.
