Offline Eddie7979
#1 Posted : 24 December 2023 10:43:49(UTC)
Eddie7979
I know I been posting a bit here, seems like I been having problems with whatever I touch recently.
Something I thought would be straightforward is the installation of the LED lighting in some Roco coaches I have. For something defferent (for me), I went for the ESU digital interior lights.
So, I have it all installed and added it on the central station on a DCC address 3 - it all worked! But then I wanted to go change the address and change the CVs to simulate the flickering of the fluorescent lights.
On the programming track it goes but then, my Central Station 3 won’t read the decoder.
Not sure what’s going on, anyone have the same issues?
PS - I have Roco DCC locomotives and they are all work fine. So I don’t think it’s the CS3
Any comments or advice is most welcome
Eddie
Eddie
Perth 🇦🇺
Marklin | Roco | Piko
CS3+ & Rocrail
Offline mario54i
#2 Posted : 24 December 2023 11:00:43(UTC)
mario54i
I don't have CS3 and these strips, but this looks like the usual behavior of function decoders.
Do you get an error when trying to read or write a CV ? Did you try to change e.g. the address and see if the lights respond to the new address?
Offline Eddie7979
#3 Posted : 24 December 2023 11:11:34(UTC)
Eddie7979
Thanks for your comment, all the best for the festive period.
When using the default address 3, it works fine. I tried to change the address and read the decoder but keep getting errors.
I decided to give it a break and the try again tomorrow. I may decide to just use normal LEDs without the decoder.
Eddie
Perth 🇦🇺
CS3+ & Rocrail
Offline BenP
#4 Posted : 24 December 2023 13:54:10(UTC)
BenP
CS3 update to 2.5.1 reportedly has some ESU decoder issues.
Offline Eddie7979
#5 Posted : 24 December 2023 16:40:15(UTC)
Eddie7979
I know, I went back to the previous update actually. I had some issues with the new update as well.
Eddie
Perth 🇦🇺
CS3+ & Rocrail
Offline Eddie7979
#6 Posted : 24 December 2023 16:41:45(UTC)
Eddie7979
Hi everyone,
Looking at the manual again, there is a mention to connect a load to AUX1. I’ll be exploring that tomorrow, hopefully this will lead to success!
Eddie
Perth 🇦🇺
CS3+ & Rocrail
#7 Posted : 24 December 2023 18:34:42(UTC)
I do have digital light and they works fine with the PoM. However i found out function decoder work better together with analog lighting. Simple just use Märklins current-conducting couples and connect with severals wagons. Works excellent this way with only one pick up shoe.
Edited by user 27 December 2023 08:16:29(UTC)  | Reason: Changed some words
Online franciscohg
#8 Posted : 24 December 2023 19:45:10(UTC)
franciscohg
Chile
Originally Posted by: Eddie7979 Go to Quoted Post
Hi everyone,
Yes, yes, yes, à load in aux1 is mandatory to program the strips.
Offline Eddie7979
#9 Posted : 25 December 2023 04:21:47(UTC)
Eddie7979
Hi everyone,
This might be a stupid question but, how do I do this? I was thinking it was just connecting power to it but thinking the voltage would be too high.
Eddie
Perth 🇦🇺
CS3+ & Rocrail
Offline ocram63_uk
#10 Posted : 25 December 2023 07:47:42(UTC)
ocram63_uk
if I recall correctly there are two pads on the circuit board where you have to solder a resistance, not present in the box, that 'simulates' a motor and in this way you can program the CVs
#11 Posted : 25 December 2023 09:27:18(UTC)
Why? You have PoM and i use CV adress without problem.
Offline Eddie7979
#12 Posted : 26 December 2023 07:30:43(UTC)
Eddie7979
I ended up figuring it out, with your help and an earlier post I ended finding after I wrote my post.
As guide to anyone else out there struggling with this LED strip, what you need to do is add it to your Central Station 3 and input address 3 on DCC mode.
After that, place it on the programming track to change the address and program it. Where I had issues was trying to read the decoder and just changing the address, which doesn’t word.
What I did, I entered the desired address to CV 1 using the web interface of my CS3. Unfortunately (in my case), the CS 3 alone wouldn’t let me do it.
I also changed the address to what I entered in the CV, then it all worked.
While this was really cool I decided to use the analogue strips because I just couldn’t find a way to make it work with the current conducting couplers. I ended up burning out one of the decoders, so decided to go back to something more simple.
Thank you all!
Eddie
Eddie
Perth 🇦🇺
CS3+ & Rocrail
#13 Posted : 26 December 2023 07:54:51(UTC)
You don´t need to use programming track to change adress of the CV1.
ESU digital light are difference from locomotive decoder.
ESU 50708 CV1 adress works with PoM.
Offline Eddie7979
#14 Posted : 27 December 2023 08:52:18(UTC)
Eddie7979
I am using the Viessmann current conducting couplers because I find they work well with the Roco coaches.
I am curious to know how you have set it up the wiring. If you don’t mind sharing, I’d be keen to know.
Eddie
Perth 🇦🇺
CS3+ & Rocrail
#15 Posted : 27 December 2023 15:45:51(UTC)
I post here a picture of the draw connect with analog light and a function decoder.
Remember...you cannot use digital light connect with other digital light together.
That´s way you need one pick up shoe in every wagons where the digital light gets the power from.
By the way...did you tested ESU digital light on the regular track by read decoder and change the adress in CV1?
Offline mario54i
#16 Posted : 27 December 2023 18:12:03(UTC)
mario54i
Why ?
#17 Posted : 27 December 2023 18:28:47(UTC)
Why ?
I have to ask the same question, after all, Marklin didn't need to in the King Wilhelm train set, they used one decoder for three wagons.
Online franciscohg
#18 Posted : 27 December 2023 19:17:04(UTC)
franciscohg
Chile
you absolutely can.
I use 2 pole conducting couplers so in the rest of the cars i dont even use ground springs.
One pickup and one ground springs for the entire train with digital lights by ESU.
#19 Posted : 27 December 2023 22:31:04(UTC)
Why ?
They install analog lighting and used one decoder.
#20 Posted : 27 December 2023 22:35:56(UTC)
you absolutely can.
You use one same adress but if you released wagons from the wagon who has pick up shoe they loss power feeder.
In fact when you change value or control digital output functions all the lighting react at the same time.
Edited by user 28 December 2023 11:23:49(UTC)  | Reason: Not specified
Online franciscohg
#21 Posted : 27 December 2023 23:20:19(UTC)
franciscohg
Chile
I do not use same adress. And the whole consist is meant to run together always. One is the Fleischmann Gambrinus FZug and the other is the Fleischmann alte Preussen.
They work just fine and with much lesser friction (and noise) than if i would be using one pickup shoe for each car.
#22 Posted : 28 December 2023 08:39:41(UTC)
I did tested same way and there was power feed to the next wagon.
I did also tested with analog light as second wagon feed by the first digital light and there was no respons.
I did draw another sketch which are your idea.
By the way...did TS fixed problem by change adress and read decoder in the CS3?
#23 Posted : 28 December 2023 11:22:10(UTC)
I did tested and found out that is a good way too by use digital light with only one pickup shoe and use as power feed to next wagons install with digital light.
And yes you can even use difference adress.
I did also use PoM by change the adress of the digital light.
Works perfect.
#24 Posted : 28 December 2023 11:25:40(UTC)
Why ?
Sorry my fault...of course you can use digital light to next same.
#25 Posted : 30 December 2023 21:20:00(UTC)
I have problems with Märklin current couple so i did ordered Viessmann two pole current couples so hopefully this time will fix the problem.
I have no problem by use PoM to change ESU adress at CV1.
I wonder if TS did also fixed problems too?
Like to read DCC with CS3?
Offline Eddie7979
#26 Posted : 09 January 2024 14:05:32(UTC)
Eddie7979
I totally forgot to reply, I was able to change the address in the end.
I still have no idea how to wire it up with the current conducting couplers. I need to keep trying and work out a way.
Eddie
Eddie
Perth 🇦🇺
CS3+ & Rocrail
This page was generated in 0.792 seconds.
