Offline Puttputtmaru
#1 Posted : 11 December 2023 15:29:58(UTC)
Puttputtmaru
Views messages in topic : 201
Designing my new layout with Wintrack. I am progressing nicely after a learning curve as with any software.
Regarding layer, is there a way when working on a layer to make everything that you add to it « assigned » a specific height for that very layer.
Unless I missed something, when I am in a layer and add tracks, for example, they all get assigned the «0 » height and then I have to assign them the height for that very layer. Any way to make them be assigned automatically that specific height for the layer I am working on? (It would save time and aggravation)
Hope I am making myself clear. Thanks
#2 Posted : 11 December 2023 16:24:18(UTC)
Hi Putputmaru
Wintrack is a great software. I love it
First you need to decide which minimum height you want between levels. This is the sum of the base plate thickness, the rail height and the clearance for you to reach things.
To make the story short, I selected 100 mm and this is fine for tracks near the edge of the layout but too small for reaching an issue on a shadow station away from the edge (or to change a switch motor (yep, happened to me)
So, now to answer your question:
- levels are meant to separate a part of the layout with others but not at all to define the altitude of each rail's extremities
- one typical way of doing things is to define the "altitude" of the main station (e.g.: 120 mm)
- next you have track going to other places (e.g.: a mountain station)
- so you define the "altitude" of the main station (e.g.:240 mm)
- if you click on any rail of the track between stations and select 3D, you will have the altitude of each track and the average slope.
- you may ask Wintrack to smoothen the slope for you
- doing so, now the track slope represented is very smooth
Once you have done this you may want to correct (fine tune) the slopes:
- the track before or after a slope is smoothly rounded (you don't go straight from horizontal to 3% in only one rail join
- best is to avoid slopes on ANY point or DSS or crossing but smotimes you need to cheat a little. In that case, clicking on the switch you may define the altitude of each extremity (3 or 4 extremities
- avoid slopes bigger than 3%
- avoid slopes on ANY points DSSs and crossings
- avoid "S" shaped track especially in R1 (there must be a straight in-between
Once you layout takes shape you may look at 3D representation and one very nice fonction allows to points places where the spacing between levels is maller than the predefined height (by YOU)
Here is my main level including Top (elevated) and main level (Main station)
Here is the bottom level 'Shadow stations)
And here is how the 3D layout looks like (Sorry, old Wintrack version)
And here is the result (I am not very proud of it but it shows the layout designIMG_4817.jpg
NOTES:
- during your work, you may decide to display the height (altitude) of each track junction but sometimes too crowded ( with track reference)
- it may be usefull when you are close to finish to compute the length of each siding and weite it on the layout
- Wintrack will display all abnormalities: rails not joined, altitude difference, etc
I hope this helps
#3 Posted : 11 December 2023 17:17:45(UTC)
Puttputtmaru
Thanks for the detailed answer.
I will have to look into the defining station heights idea that you bring forward. This seems like an easy solution.
I am still far from the details that you have on your plans but a work in good progress so far.
Beautiful layout by the way, I had looked at it before browsing this forum.
thanks 2 users liked this useful post by Puttputtmaru
This page was generated in 0.482 seconds.
