Offline Tummy
#1 Posted : 10 December 2023 07:39:49(UTC)
Tummy
I cannot get iTrain to detect the feedbacks from my layout, my details...
- Trial version of iTrains
- Mac computer
- CS3+ with a single attached S88 module (via ethernet to the underside of the CS3+)
I prepared my contact tracks by separating the rails and the CS3+ detects each block correctly.
I can connect to the CS3+ via iTrain and run the trains manually and change the turnouts.
Using the feedback monitors in iTrain none of the feedbacks trigger and per the switchboard, none of the feedbacks light up.
In iTrain - interface panel
general tab
- type: marklin central station 2/3
- control type: all checked: vehicles, accessories, feedbacks, boosters note: I do not have additional boosters attached
- feedbacks
-- switch on delay: 0ms
-- switch off delay: 250ms
specific tab
- feedbacks
-- S88 module count checked and set to 1
-- CdB-GleisReporter ID not checked and disabled value is set to 0
In iTrain - feedback example (contact track attached to terminal 1 on the S88)
- type: occupancy
- length: 160.9m (measured)
- inverted: unchecked
- interface: (my interface) CS3P
- Input device: S88 (link + GFP3)
- Bus: S88 GFP #0 (16)
- Port: 1.1
Any assistance would be appreciated, thanks!
Offline PerR
#2 Posted : 10 December 2023 08:30:44(UTC)
PerR
Which software version do you use on the CS3?
If you have updated to version 2.5.1, then the feedbacks does not work.
You will have to wait for version 2.5.2 or downgrade to version 2.4.1.
Per
Offline Tummy
#3 Posted : 10 December 2023 17:22:08(UTC)
Tummy
Per
Ahh ok, yes I'm running 2.5.1 (0). Thank you! I'll wait for the next update.
This page was generated in 0.338 seconds.
