Offline AlexLGB
#1 Posted : 07 December 2023 10:55:03(UTC)
AlexLGB
Hello
I want to know if it´s possible to connect the Marklin´s smoke unit of the LGB loco 26270 to an ESU loksound XL. Is it possible?. What cables i have to connect?
Thank you to everyone.
#2 Posted : 07 December 2023 16:58:42(UTC)
Hi Alex
I have the following remarks:
- the LGB 26270 is a cog wheel locomotive with a smoke unit that is pulsated by a wheel sensor. The manual even says that because of high currents there is a possibility to disconnect it
- each LokSound XL output maximum current is 500 mA so check with a multimeter or with your CS3 what is the current increase when turning ON the smoke unit. Chances are it is welle below 500 mA.
- you must pay attention to keep the pulsating effect (as originally designed) as the smoke unit may NOT be good for continuous operation.
- ESU decoder, similar to Märklin ones may have the smoke modulation for a given output (Mars lights, blinking, smoke, Telex) but I dont know which CV needs attention
Note: in HO, Märklin pulsating smoke unit current is approx 100 mA
I hope this helps
This page was generated in 0.295 seconds.
