Offline Astro60
#1 Posted : 04 December 2023 03:57:01(UTC)
Astro60
New member here. Thanks for letting me join. I am setting up my Marklin layout after moving, and I have some surface rust on the inner portion of my 1950's-1960's era Markilin turntable. I only need to paint the inside of the turntable (the inner part, inside of the circular "ring" gear). Is there a paint color code for this, or do I have to somehow match the color. Thanks.
thanks 1 user liked this useful post by Astro60
Online marklinist5999
#2 Posted : 04 December 2023 11:40:21(UTC)
Welcome Astro! I don't have a turntable but that is a great classic. Have you tried a rust remover? If it is very thick, and must be repainted will you be airbrushing? That would be a way to custom mix colors. Otherwise, a spray flat enamel, unless you don't care about brush streaks. I can only guess a medium gray to simulate concrete.
Online JohnjeanB
#3 Posted : 04 December 2023 12:01:23(UTC)
A warm welcome to this great forum of Märklin friends
The colour of the 410NG then 7186 has changed over the years and was NOT uniform.
Here is a video on my 1951 410 NG turntable
As you may see, in this version:
- the border and the bridge are middle grey
- the circular rack zone and the track on the bridge is dark grey
- the pit's bottom is medium beige / cream colour
- cabin is silver, window rims in white, roof in dark bordeaux / brown
Here is a 7186 from approx 1961
Later 1958-1975 the 7186 was like this
- reduced nuances of colours, medium grey
- darker nuance on the track on the bridge
- cabin's roof still Bordeaux, no red glob for light
I hope this helps a little
Offline Astro60
#4 Posted : 04 December 2023 18:27:44(UTC)
Astro60
Thanks! I'll be cleaning up the rust, and plan on painting with an airbrush. It looks like I'll have to bring it to a hobby shop or paint store to see if I can get close with the color.
Offline Astro60
#5 Posted : 04 December 2023 18:34:35(UTC)
Astro60
Thank you so much! I just checked and mine does not have a light in the cabin. Also, the box that it came in is the lighter blue color. Would this help in determining the era and colors?
Offline BenP
#6 Posted : 05 December 2023 17:43:14(UTC)
BenP
A flat, slightly darker gray base would work fine with lighter original rim and bridge. Just my take.
Online JohnjeanB
#7 Posted : 05 December 2023 18:15:32(UTC)
The light blue box colour is typical of the 2nd half of the 60s (1965 to 1970)
Ideally, the mix of 2 paint colours (dark grey and medium grew covered with satin varnish) would be great using an airbrush
Here is the box of that time
and here is the decoration à that time
Sounds like a nice project.
Offline Astro60
#8 Posted : 05 December 2023 18:50:53(UTC)
Astro60
Thank you for the color information. I'm going to try to match the paint as best as possible.
Offline Astro60
#9 Posted : 05 December 2023 18:53:36(UTC)
Astro60
Thank you for the information! This is the same box and unit that I have. Colors look exactly the same. I'll have to try to match the colors as close as possible. Will be a winter project!
Offline mbarreto
#10 Posted : 05 December 2023 18:58:03(UTC)
mbarreto
As the result will not be the original paint, you can paint it the color you like...
If you google images of the turntable you will see the different variations. Of course the exact RAL will not be displayed :-)
There is at least one version where the color of the base circle is darker in the outer part and gradually goes lighter to the center of the circle. Then the border
is also not homogeneous in that it kind of have dots imitating gravel (that's what it seems to me).
In Youtube you can see some videos of turntable weathering, which may also produce even a better look.
Miguel
Miguel
Mostly Märklin H0.
Offline Astro60
#11 Posted : 05 December 2023 19:03:53(UTC)
Astro60
Miguel
Thank you! I'll check on the YouTube videos. I have all Winter to do this, so I have time to do a nice job.
This page was generated in 0.820 seconds.
