Offline TEE2008
#1 Posted : 22 November 2023 12:40:28(UTC)
TEE2008
Hello everyone,
After a long time, the beautiful Piko 51811 110 469-4 TRI has arrived as a new addition. As you can see from the item number, it is the AC version with Piko Smart Decoder 4.1 from the factory, which is suitable for mfx.
The factory-set driving characteristics under DCC 128 driving stages are very nice. Creeping at driving stage 1 is almost possible without jerking. There are no dropouts on switches. The acceleration from driving stage 1 to the highest driving stage is nice and even. The factory-set top speed was set a bit too low. The braking delay is set a bit too high, even if it probably corresponds to the prototype. The long skid rattles less than usual with this long skid variant. Piko would be well advised to install a whisper skid.
I have turned off the mfx function and Railcom via CV programming, as mfx does not work so well (registration takes a very long time and only works after the third attempt) and Railcom is not needed.
The switchable functions are: Light on / off, red tail light on / off per side, cab lighting, engine room lighting, and a switching flash.
Edited by user 23 November 2023 11:46:18(UTC)  | Reason: Not specified
Tobias
thanks 9 users liked this useful post by TEE2008
This page was generated in 0.165 seconds.
