Offline trainman11
#1 Posted : 14 November 2023 13:04:28(UTC)
trainman11
I wondered if it is possible to deactivate the sound effects of mfx locomotives?
For example the engine in the Start Up pack no. 29453 has "Diesel locomotive op. sounds".
I would be using the digital controller from this pack.
https://www.marklin.com/...ts/details/article/29453
I wonder how to deactivate the sound, not switch it on/off with the remote controller. Is that possible at all?
Many thanks for any thoughts on this.
Steve
#2 Posted : 14 November 2023 13:49:33(UTC)
Why would you want to? Just don't turn the sound on at your controller. The sounds are not a default "ON", but OFF.
Offline trainman11
#3 Posted : 14 November 2023 13:57:39(UTC)
trainman11
I suspect that the kids will go crazy with it and I will have permanent Diesel engine sound around the house.
#4 Posted : 14 November 2023 14:00:14(UTC)
You cannot disable the sounds with that starter set controller.
An MS2 could do the trick. Or a soldering iron.
Offline trainman11
#5 Posted : 14 November 2023 14:01:35(UTC)
trainman11
OK - thank you!
#6 Posted : 14 November 2023 16:50:33(UTC)
OK - thank you!
Yes, the easiest way would be to open the loco and cut one of the speaker wires. Put a bit of tape to hold the two ends of the wire apart and so it doesn't short to anything else.
Offline trainman11
#7 Posted : 14 November 2023 17:05:16(UTC)
trainman11
OK - thank you!
Do you reckon that is relatively straightforward with digital locos?
I'm only familiar with analogue ones on the inside.
#8 Posted : 20 November 2023 23:07:13(UTC)
(not withstanding the various versions of mFX decoder ...)
I can think of at least 3 , non-intrusive, configuration options for this.
* Un-map all the sound selections from any Fx button
* Set the volume to 0
* introduce the "Mute" logical function
In the case of the Mute function I would utilize the "always on" special function to invoke.
This would be my preference as it retains the sound mapping and volume in case you wish to UnMute in the future
The actual re-configuration of options (above) may not be performed with the "IR-Controller' (Märklin Power Control Stick) of the 29453, however if you have a colleague, club or dealer with a CS2 or CS3 they may be set and the settings will subsequently persist, when you return the loco to your own 'Start-Up" layout
Edited by user 21 November 2023 07:54:01(UTC)  | Reason: Not specified
This page was generated in 0.498 seconds.
