Offline Model Railway shed D
#1 Posted : 07 November 2023 15:39:34(UTC)
You have been a member since:: 31/03/2023(UTC)
Good Afternoon Everyone
I'm new to Marklin so looking for a little help
I'm fitting my first point motor in my Marklin C track
I'm using a mobile station two but I want to control my points with a 72720
I understand both blue wires go to the box.
Can I use track power to work the point or do I need a separate power source?
Does the yellow wire go the positive wire of the power or negative?
Thank you for any help
#2 Posted : 07 November 2023 17:30:42(UTC)
If you wish to control yourpoints "the analogue way" with a 72720 control box, you need a separate 16 VAC power supply
- brown or one pole to the track 0 connection and to the 72720 control box common (on its side)
- yellow or the other 16 VAC pole to the yellow wires of each point's motor.
ATTENTION: Never Ever connect the yellow to the B of track as it will destroy your Mobile station or its track box.
This page was generated in 0.333 seconds.
