Offline Palerider
#1 Posted : 30 October 2023 17:01:23(UTC)
Palerider
Where might I find a replacement idler dear for this F800? Is there a part number? It’s 18tooth /2.5mm shaft. Thanks in advance. IMG_2065.jpegIMG_2064.jpegIMG_2075.jpeg
thanks 2 users liked this useful post by Palerider
#2 Posted : 30 October 2023 19:54:06(UTC)
It's beautiful and I'm sure you'll find a gear. A machinist with a lathe can make one.
#3 Posted : 30 October 2023 20:38:38(UTC)
If no-one beats me to it I'll look out my parts manual tomorrow.
Offline Palerider
#4 Posted : 30 October 2023 22:45:24(UTC)
Palerider
Thank you 👍🏻
Offline persmc5
#5 Posted : 31 October 2023 10:27:28(UTC)
persmc5
F800.pdf (162kb) downloaded 26 time(s).
hope this can help.
The idler gear is the same for the 3031/3032
regards Per
thanks 2 users liked this useful post by persmc5
#6 Posted : 31 October 2023 13:33:50(UTC)
Hi Palerider
I believe you may find it there under the part number 00.452.8.0 (near the bottom of F800 parts page.
https://ttn-shop.com/ersatzteilliste_f800.php
Check the dimensions before ordering
Offline Palerider
#7 Posted : 31 October 2023 17:48:01(UTC)
Palerider
hope this can help.
regards Per
Thank you. I found a set on eBay searching that part number. They don’t appear to have a snap ring groove on the shaft, but I’ll just use my old shafts if need be.
#8 Posted : 31 October 2023 21:57:35(UTC)
hope this can help.
regards Per
I suspect you may need a full set of gears. From my memories of my Dad servicing these when I was young the gear teeth get very worn on all the gears. Replacing just one gear may not sort out whatever problems you have that is ccausing you to want to replace this one.
Offline mvd71
#9 Posted : 01 November 2023 01:36:20(UTC)
I agree with Alan, take a detailed look at all the gears, if one is worn out many of the others won’t be far behind. And putting a new gear in mesh with old worn gears will accelerate further wear.
I have found with the old locos of that vintage, replacing all the gears, the armature, and the driving wheels results in a beautiful running loco.
If you are struggling to find gears, try Ritter restorations.
Cheers…
Offline mountainroads
#10 Posted : 01 November 2023 02:29:12(UTC)
mountainroads
Unsolicited plug for AC Eurotrains. I was very happy with their service on my 3047.
- MR
thanks 1 user liked this useful post by mountainroads
This page was generated in 0.794 seconds.
