Offline ocram63_uk
#1 Posted : 26 August 2023 20:10:57(UTC)
ocram63_uk
In a set of tinplate coaches there are interior lights. The coaches have a contact shoe too. Can I run them on a digital layout or not? I'm confused on this. I could try but do not want to ruin my Ecos. Maybe they could only flicker and that's it 😊
Thank you
#2 Posted : 26 August 2023 20:18:55(UTC)
Thank you
I think we need to know more details, but ASSUMING that we are talking about the standard 2-bulb interior lighting from Märklin, this is what would happen;
The lights were made for 16Vac, but will survive short 24Vac pulses.
Your digital voltage will probably be around 19V, so the light will be bright, and yes, it will probably flicker, and lifetime of the bulbs could drop, because of the higher voltage.
Being incandescent bulbs, they will also consume a lot of current. Around 1VA per bulb.
In the case of standard Märklin lighting kits, they won't damage your ECOS.
If it turns out that we are talking about a more modern, buffered, LED-equipped set, there should be no problems whatsoever!
Offline ocram63_uk
#3 Posted : 26 August 2023 22:42:51(UTC)
ocram63_uk
these are coaches made in the 60s that have the 60s interior lighting, so proper light bulbs 😊
Offline mvd71
#4 Posted : 26 August 2023 23:10:25(UTC)
I used them in the past and it was no problem on digital, but they do use a bit of the track power if you have a long train
#5 Posted : 26 August 2023 23:40:58(UTC)
Thank you
The answer to that lot is to change the bulbs for 20V ones. If the fittings are the type that have the 2 pin bulbs that plug into sockets then 20V bulbs are definitely available from Marklin. If the bulbs are the screw in or bayonet type then I think 20V bulns are available, but I would have to go looking for a part number.
Offline Bill L
#6 Posted : 26 August 2023 23:55:38(UTC)
Bill L
are these the lights in the tin-plate cars. These are very bright and do use up a lot of power.
https://www.maerklin.de/...cts/details/article/7077
Offline ocram63_uk
#7 Posted : 27 August 2023 07:49:49(UTC)
ocram63_uk
Bill, they are exactly the same at your link
Offline ocram63_uk
#8 Posted : 30 August 2023 10:21:38(UTC)
ocram63_uk
inside the coaches I have a few 7077 lights, in one I have a 484/3 light block.
I believe the pickup shoes are the 7198.
The restaurant cars, item 342/2, have the live or B wire coming from the roof pantograph, which I will remove using pickup shoes for both of them.
Correct bits identified?
Offline heinrichhess
#9 Posted : 30 August 2023 23:28:25(UTC)
heinrichhess
i use them with no problems i have added capacitor to the system on mine but not needed
hess
#10 Posted : 31 August 2023 13:44:48(UTC)
Do you mean that you have isolated the 7077 lights completely from the metal-wagon, and then rectified the power coming from the slider and THEN added a capacitor? Confused
(-Because in an AC environment, the capacitor will just be a resistance)
Offline ocram63_uk
#11 Posted : 03 September 2023 08:36:39(UTC)
ocram63_uk
Hess, do you need a rectifier bridge do attach the condenser to? I'm powering the lights via my Ecos control station.
Have you got a diagram of how you dis it, please?
Offline ocram63_uk
#12 Posted : 09 September 2023 10:09:19(UTC)
ocram63_uk
UPDATE: i placed the coach with the 50s light kit and the lights work, current used for three lights is 187 mA as shown on Ecos monitor.
I found similar sized LED bulbs on ebay and got them.
The set of 3 lights uses up 23 mA, which is good.
These are the LEDs on ebay: 325420780782
Problem, they flicker badly. Is there something I can do? Use a function decoder to power the lights? The seller proposed to send over the AC ones but I believe it will make no difference. Thank you
#13 Posted : 09 September 2023 11:08:19(UTC)
I am surprised that old light bulb still exist of today...
Greetings & A Few Simple Questions (H0-scale)
by Trigster 03/12/2017 05:32:56(UTC)
Two simple questions (Digital)
by transform609 06/03/2013 00:19:29(UTC)
Simple question about combining analogue operation and MS1 digital operation (Digital)
by Chris6382chris 08/04/2011 04:41:23(UTC)
This page was generated in 0.908 seconds.
