Offline TEEPOL
#1 Posted : 06 September 2023 15:50:06(UTC)
TEEPOL
I have 13 old analogic locos bougt in the 70's, working very well and I am thinking about transfering my net to the digital.
I am just begining to buy secund hand digital locos and I plan to share my network in 2 : Analogic and digital.
First of all I am wondering what kind of central unit 6020 : 6021 : 6035 ...or Mobile station CS 2 / CS 3 to buy.
I am lost with the different models and how it is connected to each other
I plan to have 2 or 3 locos with sound but it is my priority.
Have you any documentation to understand what kind of station to buy and the different parts of the puzzle ? (secund hand preferred for cost reasons)
Thanks for the help
Edited by moderator 20 February 2024 03:00:42(UTC)  | Reason: Not specified
thanks 1 user liked this useful post by TEEPOL
#2 Posted : 06 September 2023 16:32:12(UTC)
Welcome Teepol! Firstly, newer decoders and sound decoders are MFX, so a 6021 is limited in functions, at least without complex key strokes on the keypad. It is also only compatible with a CS3 with a 6021 connect box, which adds a substantial cost. The MS2 does a lot more. and can connect to a CS3 for a second controller, recieving which ever Locos you add to it fro the CS3. It is also updatable with a CS3, as the updates are sent to a CS3. An MS2 can be update via the web, but is complex.
A CS3 plus includes a LAN port on the bottom to connect feedback decoders without a need for an extra adapter or power supply. Both have a powerful booster.
I suggest the CS3 big book which explains new and former digital systems and compatibility.
Offline Martti Mäntylä
#3 Posted : 07 September 2023 02:28:06(UTC)
Martti Mäntylä
Hi Teepol,
I am not sure how far you want to carry your aspiration of combining analog and digital operation.
Anyway, faced with a similar starting point as yours, I decided to build a hybrid of analog and digital that allows me to run both analog and digital trains with a uniform and high level of automation.
To achieve this, I need a Märklin 60116 track box hooked to a computer through a CAN Digital interface. To control the setup, I use Rocrail.
Other than the track box, I have felt no need to acquire a CS.
- Martti M.
Offline einotuominen
#4 Posted : 07 September 2023 06:22:35(UTC)
einotuominen
Have you considered in upgrading your analog locomotives to digital and having only digital track?
Upgrading old locos is not too difficult in most cases.
BR,
Eino
#5 Posted : 07 September 2023 10:26:09(UTC)
Thanks for the help
Hi TEEPOL (Un prénom serait super)
First it is great to have you with us. A warm welcome to this great forum.
Here a Märklin fan from Ile de France, started in 1961 with M track, a loop of rails and a 3037 (E41 loco) and now with a permanent layout with digital and PC control (Rocrail
Here is a glimpse of my present layout with C track, if you are courious
https://www.youtube.com/watch?v=F6WnhXPcRqI
What kind of Central Station?
- I used a 6020 (the very first Central Unit), then 6021 (with MM2 protocol), then CS1 60212, then CS2 and now CS3
- 6021 was really a good unit, mine is still working but now quite outdated
- CS1 was a scam by ESU resulting with a legal fight between ESU and Märklin, so poor unit, poor display, no update no maintenance
- CS2 was an excellent unit (60215) provided you avoid early units 60213 and 60214 which had a design problem (no galvanic separation. Only one drawback: they are not maintained by anyone (so when it fails, it goes to trash)
- CS3 is very good but expensive (I purchased mine in Germany like 2 years ago for approx. 580€).
Just a suggestion here but why not starting with a digital stater kit (I just bought a 29243) or a Mobile station 2 with its trackbox 60116 and its 36 W power supply.
It will allow you to taste digital before making large investments. Drawback you give up the possibility of feed-back signalling
Connection to digital modules
- locos need to be digital or upgraded using digital kits mostly for DC motors mLD3 low cost), mSD3 (sound) or for old Märklin locos with "universal" motors (winded inductor)
- switches or signals could be analogue (regular wiring totally separated from the digital part) or digital using either a 4-way decoder M83 (60832) or imbedded decoders 74462 (more expensive but great for carpet trains and not good for permanent layouts). Avoid using 6083 modules (cheap but no safeguard to turn the solenoids off)
- detection is only applicable with central stations (6021, 60212,60213-60216, 60226). It uses the S88 family (now 60881, 60882 (for DC), 60883 (Link 88 (required with CS2s or CS3 (60226). Avoid using older generation of S88 (6088, 60880) with its flat cables, prone to bad contacts and electric interferences.
Digital and analog together?
- If, by accident, digital power is connected to analogue power, the risk of destruction is really big
- so the best is to have 2 independant zones, one for analogue, another for digital without any connecting track inbetween.
- another possibility is to install a switch to feed your layout EITHER with digital or with analog power.
So looking forward to read from you and your projects
Cheers / Amicalement
#6 Posted : 07 September 2023 10:38:45(UTC)
That sounds hard. Do you have any links about the legal issues between Märklin and ESU?
The CS1 is a good unit and it is still receiving updates from ESU.
#7 Posted : 07 September 2023 11:43:39(UTC)
Hi Tom
All is a matter of opinion. Mine is that the CS1 is a piece of junk with flimsy add-on modules, not user-friendly, not readable, no power, so I stop using it 2 years after purchase. Besides I collect Märklin, not ESU.
ESU's updates are now long finished and already in 2010 (when I got my first CS2) this was like day and night).
So I would not advise ANYONE to purchase such a unit (60212)
Offline blid
#8 Posted : 07 September 2023 13:19:28(UTC)
blid
There is a huge difference between the Marklin CS1 and the the more user friiendly and very capable ESU version CS1 Reloaded. I think Tom is referring to the still supported Reloaded version.
Online kiwiAlan
#9 Posted : 07 September 2023 14:29:28(UTC)
I am aware there was some form of legal action, but the claims and counter claims I do not know anything about.
I do know that the booster for the cs1 that ESU produced had major problems, as well as requiring both rails and center studs to be isolated between cs and booster sections (and probably between booster to booster sections). I seem to recall that Marklin recalled them all as they just did not work, and anyone with a large layout was left in limbo for a while until they introduced the cs2. Also the whole design of the cs1 looked dated from the day it was introduced, rather like a 1960s American styling that always looked dated. I certainly wasn't impressed with its looks.
I suspect part of the legal action was involved with ESU going on to develop the original EcOS, which had a colour screen and much more modern styling, and were putting their development efforts into that when Marklin were expecting ongoing development to be going into cs1 features, which did appear to stall for quite a while.
Offline TEEPOL
#10 Posted : 07 September 2023 18:32:36(UTC)
TEEPOL
Hi everybody and a large thanks for your detailled and interesting answers.
Just to give you more information about my train net, for the moment I just plan to enter digital world only for my locos and not for signals and tracks ans switches. iIt is too much work at this step. I want only to have pleasure to drive the locos all together, some of them withe TELEX, smoke and sound.
So I have to keep all the tracks on M-type.
When I read our advices, I understand there is a real risk to mix analogic and digital net. It is important and I have to think about it.
The only reason of my choice would to prevent me to convert my 13 old locos because I am not sur it is possible (space, version of the engines...) and costs. Till now I dont feel confident to do it myself. But in the next future why not. I have just begin to buy some secund hands digital locos and it is really cheaper than to pay a shop to do it.
Dealing with my question on the good type of control unit, thanks for your answer.
Since my last message, I have loaded different notices (6021, 6065é et CS 3)
After reading you, I understand :
I can avoid these machines : 6020, MM1, CS1 because out dated
the control unit 6021 is rustic and limited but it a solid solution and maybe enough for my need to digitalie only 20 locos. A default : it needs an expensive solution to be connected later to a CS3
The CS 3 is the top but expensive and too sophiticated for my present needs the 3 next years..
So It seems that the middle solution would be a mobile station MM2 ref 60 657. (The 60 652 seems too old,isn't ?) I have seen this type of station sold for about 120 Euros.
What do you think about it ?
A last question : is there a specific problem to connect M track to a MM2 ? Or I have ony to connect two wires (red and brown) as usual.
I ask it for I have seen a specfic connection to C track on documentation
Thanks for your help
PS My name is Jean but my surname is Teepol. So you can go on by using it.
#11 Posted : 13 September 2023 10:18:51(UTC)
Hi Jean
I believe the MS2 is a good way to start:
- gives you access to all fonctions of a loco
- gives you a reasonnable power (36 W) to drive 4 locos simultaneously (older locos may be much more power-hungry 10W or more when newer are closer to 2 -3 watts
- in theory the 60652 is equivalent to the 60657 but you may get long-term surprizes because of an older hardware revision number.
- if later you purchase a CS3, you still can use your MS2 as a slave to the CS3
The MS2 restrictions
- cannot handle inputs (S88 signals) to start doing automatic operation
- loco selection is a bit primitive
- the accessory selection is by address so OK for a small number of them.
- the MS2 is of course only good when associated with its trackbox 60116 and its power supply 66360
To check price levels, I go on ebay.de (Germany) where it cost 118€ plus shipment for the pack of 3 (60657+60116+66360)
Although I have a CS3 60226 I made myself a present of a starter kit 29243 (with a BR24, 3 Donnerbüchsen, an oval of C Tracks and 60657, 60116, powersupply for 388.04€ including shipment and a 4-month paypal payment (Berlinski in Germany)
Is there a problem to connect a MS2, trackbox and PSU to M-track?
No problem provided you verify that no track has noise suppressing capacitors 5131 which would short-circuit the digital output.
So connecting the brown and red wires is very fine.
As you know, M track is not as precise as C track but since there are a lot of them you may find it with decent prices.
With metal couplers, occasional shorts may happen (coupling bar touching studs on accasion)
The other drawback is that you can't make long occupation detection streches (unlike with C or K track)
Offline heinrichhess
#12 Posted : 13 September 2023 15:27:19(UTC)
heinrichhess
hi and welcome
I run vey old second hand digital locos called delta using a mobile station 2 my reason for digital is only to run loco's in different directions on same track for shunting
I use old semaphore signals witch cut power to track i have NO digital switches all analogue and running on old m track. Using analogue loco's which I do means no control over them they run at full speed stopping only at semaphore on mainline i enjoy using them and when cash allows i will fit digital decoder i would suggest a new starter set on digital see if you like it get all you need and some c track are a good price if you don't like it sell on eBay
I put of buying digital for so long not wanting a computer taking all my fun of driving away i started with Hornby digital i was not impressed marklin digital is grate well recommend
-mobile station 2
-delta digital
-any track
-new digital starter set
-good luck hess
thanks 1 user liked this useful post by heinrichhess
Offline BenP
#13 Posted : 14 September 2023 16:49:34(UTC)
BenP
Originally Posted by: Martti Mäntylä Go to Quoted Post
Hi Teepol,
How do you connect the Märklin 60116 with a PC? It seems to have only two Mobile Station slots. And, does it manage track shorts like a control station would?
#14 Posted : 19 September 2023 19:09:48(UTC)
einotuominen
You can do it with a device called CC Schnitte by Can Digital Bahn: https://www.spielzeug-me...bahn-startset1-18ql.html
-Eino
#15 Posted : 21 September 2023 08:41:29(UTC)
Hi Jean,
Given that you wish to start off carefully without spending too much I can say from experience:
There is nothing wrong with getting a 60652 - it works well with limited number of 10 locos registered for operation at any one time.
And there is no facility for controlling digital turnouts or accessories (which you said you don't need - there are many of us think like you).
However buying a 60657 would also be good, because it is later electronics.
Yes red and brown as usual.
Offline TEEPOL
#16 Posted : 28 September 2023 23:34:38(UTC)
TEEPOL
Hi everybody and a warmfull thanks for all your advices
Sorry to be long to answer
A special thanks to JeanB. His advices were very precise and usefull.
Other opinions were aslo very instructing for me.
I discover this Forum for the first time and it is really great.
So what I did since our last talk.
I bought a MS 2 60657 on E bay
I bought 3 different types of digital loco on Catawiki (good but at the end a bit expensive with the insurance cost 9% and travel costs)
1 little 34641 with delta with telex
1 steam loco 3709 with TELEX command
1 steam loco 39012 with MFX sound and smoke
Every is running on analogic mode (except Telex of the 3709 as announced)
Every is running on digital mode and the diferent functions seem OK
Only on trouble with the delta loco. It runs normally on analogic mode but has trouble to run regularly at slow speed as if it was on the brake.
Have you a opinion about it ?
Have I to change the motor of this loco to get normal function for running ?
Thanks in advance
#17 Posted : 29 September 2023 06:02:16(UTC)
einotuominen
Thanks in advance
Hi! Good to hear you got all that great stuff!
Delta locos of course are not as smooth runners as newer digital locos.
What I’ve learned that you can greatly imorove them by upgrading the decoder to either mSD3 or Loksound 5. Some newer Delta locos already have DC motor in them, but by looking at the spare part picture of your loco, it seems to have and old field coil magnet motor. So if you want a newer decoder in it, you have to replace the motor also.
Options are to buy a Märklin retrofit motor or Esu permanent magnet. The Esu permanent magnet solution is valid if there is not enough room in the loco for the Märklin retrofit motor, as they are thicker in size.
Your loco most likely has a drum style commutator motor. If so, then the retrofit motor would be Märklin 60941.
Also the motor noise level goes down tremendously when switching away from Delta.
BR,
Eino
Offline TEEPOL
#18 Posted : 09 February 2024 10:17:21(UTC)
TEEPOL
Hi everybody
Sorry to have been silent a so long time.
I want to give you some news now.
My network has largely progressed these last 5 months.
As annonced I kept my M track and signals without problems for my new digital locos. The only trouble is the hard way theses locos stop in front a red light cutting smoke and sounds. But I suppose there is no kind solution. Maybe by using the buffer 60971 ?
After being a bit anxious I started to convert myself my old locos. It was easier than I thought including with sound decoders.
The most difficult is to manage cables in small locos when putting back thecover.
Financially it would have been mostly cheaper to buy second hand digital locos but I wanted to keep my first locos and it is really funny to do yourself the conversion. Thanks to this forum and also to the french one I learned a lot of tricks and informations on it.
Thanks to everybody and go on playing
*** Update ****
Another point I cancel my intention to mix analogic and digital network For I am progressively converting all my old locos to digital. It is safer and more simple.
thanks 5 users liked this useful post by TEEPOL
#19 Posted : 09 February 2024 11:46:49(UTC)
You've been busy! Congratulations 👏 The buffer cap. Helps maintain sound and speed on dirty or loose track joints and sections.
The brake module slows the lok. down slowly in signal blocks.
Offline Wolfram_Stn
#20 Posted : 19 February 2024 13:44:13(UTC)
Wolfram_Stn
Hello Kimball,
the 60652 is not more or less limited than the 60657 - under one condition : you must do the software updates. Otherwise they are identic - just colour has changed.
I even do see is a big evolution on hardware.
Finally, the MS2 is just a user interface - the central/booster unit is in the Gleisbox 60116. Which, as far as I know, is technically identic to further 60113, besides the colour.
This page was generated in 1.117 seconds.
