Offline sudibarba
#1 Posted : 20 August 2023 04:09:21(UTC)
sudibarba
I am moving away from digital control for my turnouts. I am moving back to momentary toggle switches. I find working with the CS 3 screen is a pain. I also like the more hands on approach of panels of toggle switches around the layout.
It’s more fun to me.
Comments?
thanks 3 users liked this useful post by sudibarba
#2 Posted : 20 August 2023 13:05:27(UTC)
Should not be a problem with the CS3 controlling turnouts. I have mine set on routes and one click of the mouse changes them to the desired position. However I do like driving trains without any software so I can understand why you would like to control turnouts by hand. I have too many turnouts to change manually and find using the CS3 is the best way to go.
turnouts
#3 Posted : 20 August 2023 13:28:03(UTC)
A few others prefer full analog too. I like using the mouse and CS3 vs. Manual or automation. Some don't even have electric solenoids and use the hand lever with a wand.
Offline rhfil
#4 Posted : 20 August 2023 16:45:52(UTC)
rhfil
I too prefer the CS3 with a mouse in fact came into the Marklin system precisely because of that advantage
#5 Posted : 20 August 2023 16:59:11(UTC)
Hi Eric
Here a Märklin fan from France with a CS3 and Rocrail control.
Just my opinion:
- The CS3 is a very nice and powerful unit (I don't regret its purchase).
- I agree, controlling switches (especially when you have a lot of them) is not convenient on such a small screen with a finger. Rapidely a pointer device (mouse) is needed
- using an external PC with a large (touch) screen and RealVNC Viewer, the CS3 screen can be displayed a much bigger way.
- since 2013, I use Rocrail to control my layout (50 to 60 switches, DSSs, etc) and it is working very fine BUT PROVIDED you don't try to control switches individually
- rather, it is about automatic train control: a mix of fish-bow operation and schedule operation.
- not controlling switches the digital way, is for you to give up the full digital control (no automatic selection of routes, etc)
It all depends on how you want to control your layout:
1 - a very low level way (selecting each switch, each signal) in real time
2 - control the layout from a much bigger perspective (you don't bother with details (track occupancy, compatibility of selected routes.
Selecting 2 means a sofware control like Rocrail, could help you a lot
Selecting 1 means that, indeed, controling switches and signal the manual way is more fun for you.
Just as an example, here is my control panel with Rocrail
In this example, you may:
- drag and drop trains: they will only obey if it is safe to do so
- set all locos in RUN mode: they will operate in the fishbowl mode (Rocrail will select, ramdonly each destination depending on occupancy and many other factors
- run following a schedule mode: each train departs on schedule to a preset destination the schedule being either a fixed time or a duration after the previous moment.
Here is a mix mode (fishbowl and schedule modes)
So I believe that past a certain layout size or complexity, you cannot control each element (switch, loco, signal) individually. You must promote yourself to train company chief.
Offline Copenhagen
#6 Posted : 21 August 2023 21:26:09(UTC)
Copenhagen
I use a mouse too. If you use toggle switches the CS3 screen will not show the turnout positions correctly.
thanks 2 users liked this useful post by Copenhagen
#7 Posted : 22 August 2023 00:47:20(UTC)
Hello Eric,
I agree with your take on control of turnouts (or any accessories requiring intervention control).
I have a layout with a CS3+ in a room 2.7 x 3.3 metres, and I can reach all the turnouts (about 20) by hand.
I would like to motorise 3 of the turnouts, but I cannot bring myself to upend the catenary and trackwork to install them.
If I did, I would use the push button control, and not the CS3.
Märklin push-button control of digital signals or turnouts
Certainly using a mouse with the CS3 is mandatory and should be promoted by Märklin in that way.
I used the CS3 for 9 months to control my trains, as a touch screen without a mouse because I did not know it was a feature.
What a painful experience that was (compared to my old CS1).
Offline Luma Moba
#8 Posted : 22 August 2023 00:57:19(UTC)
Luma Moba
Ave sudibarba,
I had to laugh seeing the last word "Comments?"
If obvious that most of us who went digital will not go back ...
but you do what you like and stay with what makes you happy!
Not everyone likes the "automatic" control of CS3 or similar.
Like John talks in his post, it always depends what you want to
do with you layout.
Well my comment about your decision:
have fun
Luma
Do not do to others what you do not want to suffer yourself
thanks 4 users liked this useful post by Luma Moba
Offline sudibarba
#9 Posted : 22 August 2023 04:20:28(UTC)
sudibarba
As usual David you have given a fine response as well as many others. I have been away a while from the forum. My layout has long runs. Not much interested programmed running or shunting.
Like to watch the trains and walk around the layout. Have well over 100 Loks and much rolling stock. Not any where near many people but it keeps me more than busy when I get back to my building. I don’t want to sit in a central control seat. Different strokes…..
thanks 4 users liked this useful post by sudibarba
Offline heinrichhess
#10 Posted : 24 August 2023 15:29:11(UTC)
heinrichhess
I run digital trains with analogue toggle switches all so use solenoid power cutting semaphore's and in my yard hand operated switches and uncouples the main thing I use digital is moving trains in different directions the old m track switches work well the only drawback to semaphore's is they will turn loco of so no smoke or sound I use this to my advantage and hold dampflok's ready to enter section's out of sight as soon as power is turned on smoke start's sound starts and all is ok and saved precious running time on smoke
IF i was to digitize or moving back to the old way i would keep semaphore's on display digital and use train whistle to let me know where trains are running how ever i have not had a fully digital system
hess
thanks 1 user liked this useful post by heinrichhess
#11 Posted : 24 August 2023 16:21:43(UTC)
Comments?
I agree with you! In fact there are still people who use analog control of the turnouts and the signals while digital locomotives uses with digital control. It’s all matter what layout you want to control. I have miniatur switch by change of the turnouts and the signals. It is cheaper too.
Offline BenP
#12 Posted : 25 August 2023 13:51:27(UTC)
BenP
I completely agree with wanting cs3 screen for controlling switches and signals. Using vnc allows larger screen on tablet or laptop, but not more detail. Just everything bigger. Using a mouse helped, but eventually I abandoned cs3 screen interface and went to PC control. Latter step is big, but offers much better interface and control of layout.
Ben
Offline applor
#13 Posted : 26 August 2023 07:36:34(UTC)
applor
The ESU decoders have outputs for manual control from a switch - the best of both worlds.
I use them with my roundhouse door servos, so I can easily push the nearby button to open the shed door, or it can be opened via Rocrail/CS2.
Wire Marklin turnouts 8561 to Rokuhan RC-03 (Small scale)
by dmazyn 22/01/2024 16:47:19(UTC)
Use of M-turnout motors in C-turnouts (General MRR)
by gimo49 20/01/2024 12:27:07(UTC)
Problems with turnouts (H0-scale)
by Arnstein 11/12/2023 11:00:30(UTC)
C track curved turnouts - single track to four (H0-scale)
by einotuominen 31/10/2023 07:38:03(UTC)
Marklin turnouts are not power-routing (General MRR)
by Yoginath 06/07/2023 14:26:26(UTC)
Wide turnouts (General MRR)
by river6109 29/06/2023 10:17:13(UTC)
m83 decoder wire length to turnouts (Digital)
by swisslocofan 27/05/2023 04:16:19(UTC)
Use AC HO Marklin turnouts with DC power supply? (H0-scale)
by Yigal 14/05/2023 07:41:52(UTC)
Pickup shoe short circuit Turnouts (24771/2)? (H0-scale)
by flyhalf 22/01/2023 20:55:12(UTC)
Märklin Wide Radius Turnouts geometry (H0-scale)
by Patrik 01/09/2022 14:32:38(UTC)
Marklin 3600 WB Remote Operated Turnouts (Collector's Corner general)
by mb300e4m 01/08/2022 21:55:58(UTC)
Rocrail and threeway K turnouts (Model railroad software)
by pmgsr 17/05/2022 21:20:37(UTC)
Intermittent switching of turnouts (Digital)
by IBtrain 03/02/2022 06:34:02(UTC)
DCCNext and M turnouts (Model railroad wiring)
by IBtrain 14/01/2022 20:13:45(UTC)
turnouts (Big scale)
by Krish 13/08/2021 08:05:39(UTC)
Sticky turnouts (Digital)
by Rwill 12/06/2021 14:04:05(UTC)
MS2 Controlling Digital Turnouts in Analog Mode (General MRR)
by Joao Zilio 15/04/2021 19:29:53(UTC)
Turnouts (Model railroad wiring)
by Mr. Ron 07/03/2021 19:21:05(UTC)
Turnouts numbering (General MRR)
by Mr. Ron 01/03/2021 23:15:28(UTC)
7270 and C turnouts (H0-scale)
by carlos.rivas16752 13/02/2021 20:34:51(UTC)
Layout issues using a 6021 and 6001 with multiple Turnouts (Digital)
by waterslip 05/02/2021 03:38:34(UTC)
Long ICE cars rubbing turnouts semaphore m track (H0-scale)
by Victor Almeida 04/02/2021 02:56:37(UTC)
Peco turnouts code 100 (H0-scale)
by Harlov 18/12/2020 19:14:22(UTC)
M turnouts 5117, 5140, 5137 5202 for long coaches (H0-scale)
by 60904 25/11/2020 22:13:54(UTC)
Marklin Switches/turnouts/points - contact cleaning (Small scale)
by Poor Skeleton 17/10/2020 20:42:30(UTC)
2265 and 2266 turnouts and 75491 solenoid (H0-scale)
by Harvey 01/09/2020 20:12:41(UTC)
M track turnouts (H0-scale)
by Benders 16/08/2020 10:30:02(UTC)
Blue Transformers to Control Turnouts in Digital Ambient (Digital)
by Joao Zilio 28/05/2020 22:34:50(UTC)
Controlling 2 turnouts with 1 button (H0-scale)
by Brian_BR96 23/05/2020 02:16:48(UTC)
Marklin 88166/7 railbus and turnouts (Small scale)
by ajayrav 15/05/2020 17:18:55(UTC)
CS3 Track Diagram, Turnouts, etc (Digital)
by Twisterdodger 08/05/2020 16:52:08(UTC)
m83 - 2 turnouts with single address (Digital)
by bzzi 30/04/2020 01:23:00(UTC)
Turnouts (General MRR)
by JoeB 18/03/2020 01:56:33(UTC)
Marklin c track curves turnouts not reaching final position (H0-scale)
by Br01 26/02/2020 13:15:39(UTC)
Using a Transformer and 7210 Switches rather than Decoders on each turnouts. (H0-scale)
by Richard Joint 07/01/2020 03:33:52(UTC)
Inverted turnouts + random stop on locos (Digital)
by denis81 17/08/2019 23:16:30(UTC)
Controlling turnouts: Mobile Station or Control Box (Model railroad wiring)
by fstrobel 12/03/2019 21:53:20(UTC)
Physical button to control turnouts with decoder (Digital)
by denis81 06/03/2019 23:06:13(UTC)
CS2 not controlling turnouts. (Digital)
by franciscohg 25/09/2018 18:40:15(UTC)
Märklin M-track turnouts with solenoids versus K & C track (General MRR)
by river6109 25/06/2018 12:46:02(UTC)
turnouts wired to bus wiring (H0-scale)
by Primo -23K 21/12/2017 04:33:54(UTC)
Incorporating Marklin 24771 and 24772 -C-Track Right and Left Wide Radius Curved Turnouts (H0-scale)
by michelvr 10/12/2017 15:15:27(UTC)
I know they tell you not to...but why? Signals, turnouts etc etc (Model railroad wiring)
by Michael4 09/12/2017 18:29:14(UTC)
SNCF 241-A and outer curve of 24671 turnouts (H0-scale)
by db60 17/10/2017 21:34:30(UTC)
please help with turnouts and uncoupling (H0-scale)
by serge360 20/07/2017 16:16:27(UTC)
Turnouts (Digital)
by Don Morris 17/07/2017 09:15:53(UTC)
Shortcircuit in Peco turnouts (Big scale)
by Jaime 11/06/2017 14:41:34(UTC)
by drnodk 07/06/2017 18:38:44(UTC)
turnouts (Digital)
by drnodk 06/06/2017 02:28:21(UTC)
Controlling M track turnouts with a 'piano'? (H0-scale)
by Michael4 11/05/2017 14:40:47(UTC)
This page was generated in 0.821 seconds.
