Offline einotuominen
#1 Posted : 10 August 2023 06:37:13(UTC)
einotuominen
I’ve ran to a problem I’ve been trying to google up with english and german keywords, but have not found the answer yet.
I’ve programmed an mSD3 decoder to have all the 32 functions available and with the latest firmware. Loco is controlled with MS2 on version 3,55. Everything works with DCC as expected, but with MFX, only 24 first functions are available.
This is true to several locos.
In all Märklin documentation it is stated that there are 32 functions available, but is this not true for MFX?
What am I doing wrong?
-Eino
Offline bph
#2 Posted : 10 August 2023 12:01:15(UTC)
Old track box firmware?
#3 Posted : 10 August 2023 12:07:07(UTC)
einotuominen
Could be. I'll ask my friend, since this is an issue he is facing.
-Eino
#4 Posted : 10 August 2023 13:10:40(UTC)
-Eino
also get the ms2 updated, 3.55 is the earliest version that could handle more than 16 functions, I would strongly recommend he take it to a dealer and get it updated to at least 3.148, or the recently released 4.1. after doing that certainly update the trackbox.
#5 Posted : 10 August 2023 14:11:03(UTC)
Hi Eino
Not sure if this is it but mSD3 have 32 fonctions only when in MFX mode: must program and operate in MFX
#6 Posted : 10 August 2023 14:15:57(UTC)
einotuominen
Hi Eino
Operation is done with MFX (tested with DCC also, obviously), but do you mean that other protocols has to be turned off?
DCC works like magic though.
-Eino
#7 Posted : 10 August 2023 14:29:45(UTC)
I never had this problem because I program and operate with MFX and all have 32 fonctions.
In the manual it says page 26 "The settings and digital functions can only be used in digital operation. However, the same possibilities are not available in
all protocols. (This is an understatement not to say that in MM2 or DCC there are less fonctions because of the protocols).
See here https://static.maerklin....bb60f4f6131663855985.pdf
You may have to disable MM2 and DCC protocols on your decoder to have access to all fonctions. This may require the use of a CS3 CS2 or Märklin LokProgrammer.
This page was generated in 0.421 seconds.
