Offline Mille
#1 Posted : 05 August 2023 13:19:44(UTC)
Mille
My question is if should go back to
factory settings on my cs3 or just delete
all savings?
I was not satisfied about my layout
#2 Posted : 05 August 2023 16:58:00(UTC)
Hi Mille
You can do both on a CS3
To delete the layout, the easiest is to change the selection for a zone selection (arrow pointing to a rectangular zone) and then delete a group of items.
This is quicker than deleting the items one by one.
Offline dlwestphalen
#3 Posted : 06 August 2023 02:38:38(UTC)
dlwestphalen
Question: if you reset the CS3 back to factory settings, does it "forget" all locos?
Denis
Offline rhfil
#4 Posted : 06 August 2023 11:53:57(UTC)
rhfil
If you reset the CS3 to factory settings it loses everything. You can build a second layout and just ignore the first. You can build as many layouts as you want.
Offline rhfil
#5 Posted : 06 August 2023 11:59:04(UTC)
rhfil
I have posted this a number of times but it needs repeating. You need to regularly save your CS3 to a thumb drive that way if something happens you can restore the saved file to restore the CS3 to a date prior to the event. That way if you accidentally delete everything or an update goes bad you can have a functioning computer again.
Even, perish the thought, if your CS completely dies you can get a new one and just load your entire old CS onto the new one. Shit happens.
thanks 4 users liked this useful post by rhfil
This page was generated in 0.494 seconds.
