Offline heinrichhess
#1 Posted : 30 May 2023 21:45:53(UTC)
heinrichhess
I'm running mfx and older decoders on steam layout running of mobile station 2. Can I get loco's to sound the whistle from running over contact track?
I'm running reverse loop to terminus stations and would like to know when train is approaching. The best I can come up is mounting a separate speakers wired to track triping power and setting of speakers
All my locos have built in speakers so seem a waste to run it that way + would be nice to have different sound from loco's. I do not have command station or software set up yet
Edited by moderator 06 June 2023 23:22:44(UTC)  | Reason: Edited for clarity - no offence :-)
#2 Posted : 31 May 2023 00:54:26(UTC)
Hi Heinrich
With a MS2 you can run digital locos (MFX, DCC, MMS2) and turn ON / OFF any of their fonctions
What you cannot do with a MS2 alone is to associate a contact with a command.
To do this, you need a CS3. Either the couple CS3 and Link88 (60226 + 60883) or the couple CS3+ and M88 (60216 + 60881)
The CS3 can read track contacts and use then to trigger a pre-recorded chain of commands. This is the event fonction
Here is a video on simple events to trigger turnouts, signals, locos etc
Here is my automatic layout using that pair (CS3+Link88) plus Rocrail https://www.youtube.com/watch?v=F6WnhXPcRqI
#3 Posted : 03 June 2023 01:26:50(UTC)
heinrichhess
thanks will watch vid now sounds like moor cash tho
Offline rhfil
#4 Posted : 03 June 2023 15:47:06(UTC)
rhfil
It is easy to do but you need the proper equipment. A CS2 or 3, an appropriate S88, and any of the track sensors - contact, circuit or reed switch.
#5 Posted : 03 June 2023 22:49:56(UTC)
Originally Posted by: heinrichhess Go to Quoted Post
i running mfx and older decoders on steam layout running of mobile station 2 can i get loco's to sound the whistle from running over contact track im running reverse loop to terminus stations and would like to know when train is approaching the best i can come up is mounting a separate speakers wired to track triping power and setting of speakers all my locos have built in speakers so seam a waste to run it that way + would be nice to have different sound from loco's i donot have command station or software set up yet
You could set up a train whistle (speaker) that would activate when the contact was tripped. it would not set off the digital whistle of that particular locomotive, but would let you know that a train was at that location. This would likely be cheaper than going to CS2/3 and the other upgrades to make it digitally feasible.
#6 Posted : 04 June 2023 01:30:03(UTC)
heinrichhess
thanks mike ci thinking about setting up a bell like sound now that would work in signal box running from contact track alerting of trains arrival
This page was generated in 0.358 seconds.
