Offline michelvr
#1 Posted : 07 January 2023 18:08:02(UTC)
michelvr
Bored Welcome news for Marklin C track lovers!
The missing C track piece is finally here from Märklin.
I just read it in the Märklin Insider magazine that I received yesterday.
thanks 5 users liked this useful post by michelvr
Offline Mark5
#2 Posted : 07 January 2023 19:10:06(UTC)
Mark5
Originally Posted by: michelvr Go to Quoted Post
Bored
Any K-track equivalents?
#3 Posted : 07 January 2023 19:21:08(UTC)
Most of us picked up on this from the Autumn New items ... about 2 months ago.
Offline michelvr
#4 Posted : 07 January 2023 19:44:23(UTC)
michelvr
You mates in New Zealand and Australia are so lucky to get the Autumn’s New items two months ago as we Canadian just had ours delivered this past week!BigGrin
#5 Posted : 08 January 2023 00:43:06(UTC)
Well, there are links to downloadable PDF copies put on this forum, and there was some discussion about it at the time.
Online JohnjeanB
#6 Posted : 08 January 2023 01:52:54(UTC)
It looks like a very nice design, very sleek, only one motor (I don't need more) but the indicator is sold separately and driven only when using the embedded special decoder.
Availability is very vague: 2023. I suspect it will be around mid-year 2023.
Absolutely no pictures of this 60720 DSS are to be found on the web, so some more development is needed.
Now my question: when will the C flexible track will be released?
Note: the fall prospect and corresponding video are available on the web since months
Offline michelvr
#7 Posted : 10 January 2023 01:36:24(UTC)
michelvr
Uh oh I realized I used the wrong emoji Bored instead of BigGrin as this is wonderful news! Cool
Edited by user 10 January 2023 15:56:10(UTC)  | Reason: Not specified
#8 Posted : 10 January 2023 06:16:21(UTC)
Not a chance that C-track flexrail will be present. It’s difficult by fix the stud contact at other side of the end by connect next track. Two rail tracks are better due to the contact rail.
Online JohnjeanB
#9 Posted : 10 January 2023 12:09:00(UTC)
Yes the flex track is difficult because of the C Track extremities, molded in hard plastic but companies like Faller mastered the injection technique of different plastics in different places.
Never underestimate human ingenuity.
#10 Posted : 10 January 2023 12:48:51(UTC)
You can do it for two rail but not Märklin C-track because of the stud contact. It is easy for K-tracks but it’s difference from C-track.
Offline LeoArietis
#11 Posted : 29 March 2023 12:47:39(UTC)
LeoArietis
Just construct the studcontact on the underside like an infinite connected Z or reversering E:s (similar to how it's done on K-track) and it could be easily bent and still maintain it's place.
It's the rails that will have to be able to either be cut to length or be able to slide into each other.
Great news the slim double slip finally is comming.
Current layout:
The former project:
thanks 2 users liked this useful post by LeoArietis
#12 Posted : 30 April 2023 19:12:27(UTC)
On the Stummiforum there are photos of the Märklin slim double slip turnout recently taken in Dortmund together with hints that it should become available in 3Q2023 (Trix verson in 4Q2023):
https://www.stummiforum....ution-90.html#msg2548626
Offline Henrik Schütz
#13 Posted : 30 April 2023 22:34:29(UTC)
Henrik Schütz
Märklin applied for a patent for flexible c track years ago..
If i find my copy of the application , ill post it hete.
Henrik
thanks 4 users liked this useful post by Henrik Schütz
#14 Posted : 01 May 2023 13:21:54(UTC)
Henrik Schütz
https://www.google.se/pa...lR_EDHSdcA14Q6AF6BAgFEAM
This is Märklins attempt to make flexible C-track
Henrik
thanks 2 users liked this useful post by Henrik Schütz
Online JohnjeanB
#15 Posted : 01 May 2023 14:31:30(UTC)
Hi Henrik
Very interesting indeed but, the patent dates back in 1989 when the C Track was being finalised.
It does not show - I think - a proposed solution to include a flexible rail segement compatible with a normal C track
In my opinion:
- Märklin is definitely working on this
- the difficulty is to mix flexibility (use of elastic and soft material) with the extremity connections (hard plastic).
- the possibility of cutting such a flexible track and still being able to connect it to other C-Track elements is imperative
- One possibility for Märklin is to provide two components: (a) the soft, flexible track as we know it today with other track types and (b) an extremity piece to connect to a C-Track element.
- so the extremity piece must be compatible with a perpendicular cut of the flexible track (if possible, self connecting and self attaching). Tricky but not impossible.
Just my opinion
#16 Posted : 01 May 2023 15:00:32(UTC)
Originally Posted by: Henrik Schütz Go to Quoted Post
https://www.google.se/patents/DE3903843A1?cl=de&dq=m%C3%A4rklin&hl=sv&sa=X&ved=2ahUKEwiQ4t3r_9P-AhWlR_EDHSdcA14Q6AF6BAgFEAM
Henrik
In the events chronology stretching from 1989 to 1990, the last entry shows the patent status: "withdrawn".
Sad
Offline LeoArietis
#17 Posted : 03 January 2024 11:29:23(UTC)
LeoArietis
I wonder when Märklin will start to sell the slim double slip.
I also wonder how they are going to pull the rails into the right position with just one standard motor.
Current layout:
The former project:
thanks 1 user liked this useful post by LeoArietis
Online marklinist5999
#18 Posted : 03 January 2024 11:38:52(UTC)
It will probably use the same same solenoid with a longer actuator than the current double slip.
#19 Posted : 03 January 2024 18:44:48(UTC)
It is due in Q2, so by end of June.
This page was generated in 0.799 seconds.
