Offline Alex H
#1 Posted : 23 February 2023 21:54:45(UTC)
Alex H
Hi.
I am going to be starting a new layout, using C track for the first time onto a layout deck of ply.
I was wondering if other users put down a cork or rubber road bed onto the ply to help reduce noise levels?
Thanks for any tips
Alex
thanks 2 users liked this useful post by Alex H
#2 Posted : 23 February 2023 22:40:09(UTC)
Hi Alex
Certainly no master at lanscaping usf but seems to me:
- having C track directly on a full size plywood sheet is noisy
- having a frame(s) structure with track supports (I use 10 mm plywood) provides a great reduction of noise, especially when you do landscaping amortizes a lot the track noise.
Below are 2 videos, one to show the structure of the multi-layered set-up, and one to show the noise absorption thanks to the landscape
The track support in plywood ("GleisTrasse")
The same layout with landscape
Note: you will notice, that the layout with landscape (2nd video) is way less noisy and so the sound level of locos has been sharply reduced when compared with the first video.
So, what I am trying to say is:
- avoid if you can a large flat, plywood surface and if you really must have one, then inserting a thin foam bed may help
- in a multi-layer layout, the noise is absorbed by the structure
Offline Michael4
#3 Posted : 23 February 2023 23:27:55(UTC)
Michael4
I use 3mm closed cell foam sheet (available online), sometimes available in different colours and very effective.
#4 Posted : 24 February 2023 01:28:46(UTC)
There several aspects of the trackwork and landscape which may afferct noise. Trackbed of course, then ballast can echo noise and even exsentuate it, so choose one not made of plastic. Also the glue used can absorb and quiet the sound.
What I used as an underlayment is good quality batted black, or dark brown or green vynil upholstery fabric. It worked under M track well, and C track. However, one track substrate is solid plywood, and one a hollow door. The solid is quiter. I thibk the space in between the inner and outer panels echos sound. The tracks running over a plaster embankment berm are quiet.
#5 Posted : 24 February 2023 02:44:25(UTC)
Hello Alex and all,
The screws holding the track down transmit the noise to any timber.
Like a violin or a guitar (made of wood) the noise is amplified to a degree.
I do not use screws to hold track down, so I dont have a noise problem.
Only the swishing of wheels on rail.
See my layout idea here:
https://www.qldrail.net/altkloster/softlysoftly1.htm
Offline Alex H
#6 Posted : 24 February 2023 20:10:53(UTC)
Alex H
Thanks everyone for your comments, advice and tips, they are really useful.
I have found a roll of 3mm underlay for wooden floors in my garage, and which is supposed to be sound deadening, so I might well lay that across all of the ply and then work from that.
Once again - thanks for the help
Alex
#7 Posted : 24 February 2023 20:39:53(UTC)
Oh, yes, that shoud be great!
#8 Posted : 25 February 2023 00:06:30(UTC)
If screwing the track to the ply, then another option would be to apply the sound deadening material to the other side of the ply to dampen any vibration in the ply to stop it acting like a drum.
Offline fbaube
#9 Posted : 09 July 2023 12:21:13(UTC)
fbaube
I thought I would try a layer of Homasote on top of plywood. Then I can use short tacks to attach track to it, without them going thru to the plywood and transmitting vibration & noise
Edited by user 17 July 2023 23:20:07(UTC)  | Reason: Not specified
#10 Posted : 09 July 2023 20:29:49(UTC)
Woodland scenics provide a selection of track base which on top of wood allows silent running. Not cheap though.
Offline Tie
#11 Posted : 09 July 2023 22:54:50(UTC)
Tie
Lots of good advice allready👍 On my layout I made the mistikake of using lots of plywood plates creating a guitar box. Should be used under the tracks only. For remaining use styrofoam or aluminun net with plaster.
I also used cork under the C tracks. Maybe ok first year but became hard as wood quickly. I Think syntetic is better. And use elastic glue. No screws.
Thor
thanks 1 user liked this useful post by Tie
Offline Toosmall
#12 Posted : 10 July 2023 01:31:55(UTC)
Toosmall
This is my car, but you maybe able to use some of my experience to adapt to make a layout quieter: https://www.freel2.com/forum/topic33026.html
In principle it is the same issues.
I have added a bit of acoustic insulation to my layout, but it has been a secondary issue to my car.
This page was generated in 0.936 seconds.
