Offline Juan Carlos Carbonel
#1 Posted : 05 February 2023 04:28:02(UTC)
I have a marklin 60052 transformer for a Central Station 2. The back of the transformer says 230VAC in and 16 VAC out. My wall oulet is supplying 237VAC and the output is 18 VAC.
My question is : will this 18 VAC damage the CS2?
Thank you
JC
Edited by user 05 February 2023 10:00:52(UTC)  | Reason: Not specified
thanks 1 user liked this useful post by Juan Carlos Carbonel
#2 Posted : 05 February 2023 12:07:02(UTC)
Hi Juan Carlos
Märklin users manual for the 60215 says
Input voltage: min 14 VDC, max 24 VDC and 16VAC (typical? does not say)
So in my opinion, such a transformer 60052 delivers 17 to 18 VAC meaning you are close to the maximum but this should be OK.
One thing is sure, in Paris we have 237 VAC and I used the CS2 with a transformer there in the beginning.
Note: I used an old PC 100W power supply (HP) with a 19 VDC delivery and the result was much better (no speed fluctuation any more caused by current variations (yes also with super duper MFX locos)
The pin layout of the CS2 power connector is here https://www.pallund.dk/cs2.htm
Now for many years I use a 60101 (100 W Märklin power supply) Much better.
#3 Posted : 05 February 2023 15:46:49(UTC)
Hello Jaun, welcome! 220 to 240 volts is fine for it. I know a few guy's who use it.
#4 Posted : 06 February 2023 09:37:12(UTC)
That should be no problem. The voltage read from an idle transformer will always be higher than the nominal voltage.
The 60215 manual reads: "Betreiben Sie das Steuergerät nie mit einer Nennspannung höher als 17 V (AC) bzw. 24 V (DC).
Es kann sonst zu Schäden an Personen und/oder Sachen führen."
Translation: Never feed the CS2 with nominal voltages above 17 V AC or 24 V DC.
Your transformer has a nominal voltage of 16 V and there should be no problems even if the mains voltage goes up to 253 V.
Did you measure the voltage of your transformer with the CS2 up and running? It will probably be a bit lower. It will be still lower with a few trains running.
Edited by user 07 February 2023 14:45:01(UTC)  | Reason: ...
#5 Posted : 07 February 2023 07:15:03(UTC)
Thank you very much for the answers to my question. I appreciate all three answers that I got
This page was generated in 0.503 seconds.
