Offline BurritoJoe
#1 Posted : 22 December 2022 13:17:35(UTC)
BurritoJoe
I am seeing a little issue with the operation of the smoke generator.
I am noticing that after it is running for a while, the smoke puffing from the stack stops while the synchronized stem from the steam boxes keeps doing its thing.
I have to turn the smoke function off and back on again for it to continue.
And also at times the steam from the steam boxes stops as well, and will work only when the function to release steam is pressed and it stops after it is done its cycle. Turning the smoke function off/on does not make a difference here.
I am using a mobile station with the 1 scale track box.
I am curious if this may be a voltage issue/controller function/ or a fault in the smoke generator or the loco electrics itself.
I am very new to this era of Marklin digital, any help is appreciated.
This page was generated in 0.311 seconds.
