Offline Jan Havenga
#1 Posted : 03 November 2022 18:47:05(UTC)
Jan Havenga
I created a consist but the locomotives are running at different speeds. How do I equalise them?
#2 Posted : 04 November 2022 12:03:13(UTC)
Hello Jan
Welcome to this great forum.
Equalizing speeds on a consist depends on the decoder type.
- on Märklin recent locos or using mLD2, mLD3, mSD2, mSD3 decoders and using a Central Station you may adjust the speed and accel / decel curve of each loco for a good match
- on simplified or old decoders, you can't.
- avoid very old Märklin digital decoders because on the Motorola (Not MM2) protocol, the direction bit is not interpreted (so the locos may go in opposite directions
Offline Jan Havenga
#3 Posted : 04 November 2022 12:49:14(UTC)
Jan Havenga
Thank you so much. Is the speed adjustment made on the decoder or on the Central Station where I have input my locomotives? If I call up any of my locomotives and go into the settings function, where do I see the speed adjustment option?
#4 Posted : 04 November 2022 13:28:15(UTC)
The speed adjustment is made on your decoder, using your Central Station as a tool.
In the Märklin terminology, these are:
- the maximum speed
- the acceleration delay
- the brake delay
- the speed curve (linear, exponencial, very exponencial). I suggest you don't make specific changes to curves in a consist.
Of course when finished adjusting, don't forget to transfer the adjustments to the decoder by validating
Here are the key variables on a CS3
I hope this helps
#5 Posted : 04 November 2022 13:53:29(UTC)
Sorry I realized you use a CS2 so here are the key variables (sorry German version)
- Anfahrverzögreung = Acceleration delay
- Bremsverzögerung = Brake delay
- Mindestgeschwindigkeit = minimum speed ATTENTION Don't set too low so the loco will avoid stalling (starts all the times)
- Höchstgeschindigkeit = maximum speed
Here is the speed curve
#6 Posted : 04 November 2022 13:56:23(UTC)
Maximum speed can be adjusted with all fx decoders, either by programming the maximum speed or by adjusting a pot. The speed curve usually cannot be adjusted.
The pre-fx c90 locos also have the pots.
It's best to use locos with identical decoders and identical motors.
Offline dickinsonj
#7 Posted : 05 November 2022 01:00:01(UTC)
Good advice Tom.
I sometimes run my crocodile double set in a MUC. That has shown me that even identical locos are sometimes in conflict. On those locos it only happens when sound is on, which controls the actual start of a loco ion newer decoders.
This page was generated in 0.438 seconds.
