Offline craigericks
#1 Posted : 02 November 2022 01:09:06(UTC)
craigericks
I have six 60880 decoders connected. All were working fine until today. Now the 4th - 6th decoders are not working. I have tried changing the cable between the 3rd and 4th decoder, but that did not fix the problem.
Tomorrow, i will try bypassing the 4th decoder to see if the problem lies with the 4th decoder.
Anybody have this problem before? Suggestions, please.
Craig
Marklin:CS2 and TrainController Gold v10
Online Johnvr
#2 Posted : 02 November 2022 06:32:09(UTC)
Johnvr
Hello Craig
Have you got CS2 60214 or CS2 60215 ?
A friend of mine cannot get the 6088 module working with the 60214.
It operates perfectly well when the CS2 is in 'STOP' mode, ie, you can see the yellow lights light up in the display area when the circuit tracks are activated, but when in 'GO' mode, all of the lights go red.
Offline craigericks
#3 Posted : 02 November 2022 18:02:00(UTC)
craigericks
Hello John,
I have 60215 and have used these S88s for a very long time. Setting up a new layout and all was working well, but for some reason, #4-6 in the chain quit working yesterday.
#4 Posted : 02 November 2022 18:12:08(UTC)
Hi Craig
I have 7 of these old style 6088 and 60880 and my experience is:
- the cable issues (bad contacts and broken cable) happened many times
- when using with my CS2 there where possibilities of plugging the cable the wrong way.
- any module may be plugged the wrong way (the arrow must point towards the CS or Link88 unit).
- now with a CS3 I started using a link 88 and all my problems disappeared on 6088 and 60880.
- I never observed a hardware failure on those 6088 modules (some of which are much more than 10 years old).
Offline craigericks
#5 Posted : 03 November 2022 01:06:45(UTC)
craigericks
Hi Jean,
That is what I don’t understand. I had tested all of the ports on every one as I was installing the contact tracks. All was well as i ran my layout. Then yesterday, as I was running the layout, s88s 1-3 continued to work, but 4-6 stopped working. I had not touched the cables nor the s88s. I did not get a chance to troubleshoot today as i had planned. Hopefully tomorrow.
These s88s are 15-20 years old.
#6 Posted : 03 November 2022 11:08:24(UTC)
Hi Craig
So it has to be the cable between unit 3 and unit 4.
Remove it gently and inspect the contacts (possibly with a thin screwdriver, bent the contct inside to force a stronger contact force, use contact spray) and for possible a broken wire (it may sometimes be almost invisible).
Also make sure that nothing is connected to the 6088 "ground" (the upside down "T") with the only exception of local floating contacts like Reed contacts.
All in all, these contacts readers 6080 are temperamental and this is why many including me moved away from this towards towards 60881 and CAT5 cables.
#7 Posted : 03 November 2022 11:17:19(UTC)
Hi Craig
Or it could be the configuration of the cs has got corrupted and reset itself to a lessor number of s88 units.
Offline craigericks
#8 Posted : 03 November 2022 18:09:03(UTC)
craigericks
Hi Jean and kiwiAlan,
Don't know what say. Fired up the layout today, and all is well. All of the s88s are reporting properly. I did try swapping out the ribbon cable between 3 and 4 the other day, but that did not seem to help. But, now all is well today. Maybe I inadvertently made the connection better somehow when I was working with the cables.
I will take your advice to heed if this happens in the future. BTW the CS2 shows all of the S88s.
My question now is: I have to add another S88 to the layout, I do have a 6088, but I know its cable is broken. Rather than buying a replacement cable, I am considering buying a 60881. Question is, “Can the 60881 be the 7th S88, or does it have to be the first one?” I know the S88s are self addressing as they are connected. Would I be able to configure the 60881 to be the 7th one, since it will not be directly connected to the other S88s as it requires to be connected to the 6017x port of the CS2. The 6 existing s88s are connected via ribbon cable to the S88 port on the CS2.
Thank you for all of your help,
Craig
#9 Posted : 03 November 2022 19:47:15(UTC)
Hi Craig
No a 60881 connot be used in a chain of 6088 or 60880. Their cable is CAT5 (Internet type) and not a flat cable.
There are some replacement Digikeisj s88 to s88 flat cable 50cm for under 10€ (kinda expensive) or the Märklin 6089 (29€ and 2 M long , a drawback because the total allowed length is not much that 2 m.
Offline blid
#10 Posted : 03 November 2022 21:55:31(UTC)
blid
Littfinski has Kabel s88 in 0.5, 1 and 2 m lenghts for 12.50, 14.50 and 16.50€. They are not flat cables but have the same connectors. The round cables are not as sensitive to interfearence as the flat ones.
https://www.ldt-infocenter.com/d...for_the_s88-feedback_bus
Offline craigericks
#11 Posted : 03 November 2022 21:58:37(UTC)
craigericks
Hi Jean,
Sorry, I did not make myself clear. On the CS2 there is a ribbon connection for the 60880s. If I were to get a 60881, it would connect to the 6017x on the CS2.
My question is, when I connect the 60881 to the CS2, can I give the 60881 the address for the 7th set of connections 7-1 through 7-16. Or how do I get the CS2 to recognize I want it to be the 7th set of occupancy sensors?
The 60880s and the 60881 would not be connected, but they would both be connected to the CS2.
Craig
#12 Posted : 03 November 2022 22:10:00(UTC)
IIRC LDT also make an RJ-s88 cable adapter.
Hmm, I thought they did, but I can't find it. They do have cables though.
They do have s88 modules that take either type of connector, with 16 inputs. You can also have it with 16 opto-isolated inputs or 8 track sense inputs for 2 rail systems. See their product page for further information.
#13 Posted : 04 November 2022 00:09:13(UTC)
Incorrect!
Marklin offer the 60884 adapter cable for one direction
The pinout is also documented so you can make your own adapter for the other direction
#14 Posted : 04 November 2022 00:18:22(UTC)
Incorrect!
Ok
I do note that latest (2020) documentation https://static.maerklin....23402d40f81604050833.pdf
has the statement "Important! Connections to 6088/60880 cannot be made"
I can only say it works for me.
Offline craigericks
#15 Posted : 04 November 2022 01:05:46(UTC)
craigericks
One correction i need to make. I have a CS2, therefore I need an L88 (60883) to connect to the CS2. I incorrectly stated I would use the 60881.
#16 Posted : 04 November 2022 21:41:22(UTC)
Hi Craig
Originally Posted by: craigericks Go to Quoted Post
Hi Jean,
Craig
When you connect a M88 or S88 to a CS2, using the flat cable connector from under the CS2 all units are self numbered depending on the order you connect them to the CS2
- first unit (connected directly to the CS2) has the addresses 1 to 16
- second unit 17 to 32
- third unit 33 to 48
- etc
So it is convenient BUT you cannot insert a unit between other without changing all the units downstream.
Here is a small table to help you with input numbers for the CS2 or CS3
Each line represents one S88 or M88 with 16 inputs
So for the seventh unit (S88), the zone in yellow, shows you the addresses of its inputs 1 to 16
This is the reason why I selected to have a Link 88 with 2 busses going in different directions
There the addressing is a bit more complicated
- inputs 1 to 16 of the lik88 have the addresses 1 to 16
- inputs 1 to 16 of the first module on Bus 1 have the addresses 1001 to 1016
- inputs 1 to 16 of the second module on Bus 1 have the addresses 1017 to 1032
- inputs 1 to 16 of the first module on Bus 2 have the addresses 2001 to 2016
For the tests, it is best to create a testing table
It goes like this
Note the bottom of the screen where a Link 88 is combined with old 6088 modules with flat cables (daisy chain) originating from the CS2 bottom.
Offline craigericks
#17 Posted : 04 November 2022 22:33:10(UTC)
craigericks
Thank you Jean,
I did understand the concept of the s88s self numbering using the flat cable under the CS2. In the layout portion of the CS2, all I did was add the appropriate numbers of S88s, in my case 7. This is all I had to do, because I use Railroad & Co’s software program, Traincontroller to run my layout. In that program I have to specify the address for indicator for each contact track.
I just read the Link S88 (60883) manual. I see that the 60880 S88s connect to Bus 3 which addresses start at 3001. If I were to use the S88 Link and then connect my 60880s to the Link, all I would have to do is change the addresses in the Traincontroller software by adding a “300” in front of the number already inputted (eg. 5 would become 3005, etc).
A much simpler, although tedious, process than I had envisioned. I would have to change 90 existing addresses.
Thank you for all of your tremendous help,
Craig
This page was generated in 0.735 seconds.
