Offline mrunix
#1 Posted : 30 September 2022 23:44:03(UTC)
mrunix
I have only a MS2 today, now looking at CS3, CS3+ or a used CS2.
The CS2 is half the money of the CS3+, what is the difference one could notice of these two?
Is it worth the money to get the CS3+ or should I get the CS2 and hope for a CS4 in a year or so then move up?
thanks 1 user liked this useful post by mrunix
Offline dickinsonj
#2 Posted : 01 October 2022 01:13:27(UTC)
The CS2 is cheaper but it runs much slower with its old hardware and the screen is marginal. The CS3 is a major upgrade in almost every way but as you know, it cost a good bit more. As an owner of a CS2 I have always found them to sell for more than what they are worth. I keep mine just to use as a slave to my CS3+.
I think the value is in the CS3, maybe not even the CS3 plus which adds things many people do not need..
#3 Posted : 01 October 2022 01:14:13(UTC)
The CS3's both have full screen fuction/icon activation. The CS2 has buttons on each side for several. The 3's may have a slightly better processor. They also include a third pop up Loco controller with the latest update. You use a finger, or stylus/mouse to use it. Your MS2 will plug into the front as an auxiliary controller.
The CS3 plus has an ethernet connection on the bottom for S-88 feedback connectivity. This elimnates the need for an external Link S-88 between the CS2, or basic CS3 and the S-88 feedback decoders. The S-88 Link requires a seperate power supply. The CS3 plus has it built in for the S-88 decoders. You need a terminal box like your MS2 uses to connect it to a CS2, or to connect a CS2 with a CS3.
Keep in mind that a used CS2 will have no 2 year warranty. Hope I was helpfull!
P.S. there are also recent Marklin digital club webinars posted on Youtube for the CS3's.
#4 Posted : 01 October 2022 01:23:48(UTC)
Hi Mrunix
I had 2 CS2 (60215) now replaced with one CS3 (60226) and here are my thoughts:
- the CS2 (especially the late 60214 and 60215 with galvanic insulation) was an excellent unit and very innovative (may be more than the CS3)
- the CS2 cannot be repaired today. Any failure results in the replacement of the CS2 by a CS3
- the CS3 screen management is totally different (same size but higher definition, different tactile detection capacitive on the CS3 making rapidly the use of a mouse.
- the CS2 capacity was reached (no more extension capability) while on the CS3 the memory has increased by at least a factor of four.
- the new Märklin software will strangle more and more the CS2. On my CS3 I could add a 32 GB memory card.
- the handling of external devices on the CS2 was linked to previous generations (the old flat cable 6088 detector, the old 6015 / 6017 booster) while the CS3 is firmly anchored to new generation devices.
Why not the CS2?
- one of my CS2 has died because of the incapacity to finish the booting-up and many CS2 have died this way. This is due to a solid state massmemory with an increasing number of mistakes. This cannot be repaired (unavailability of some circuits.
- the other CS2 I have is fully functional EXCEPT that both its outputs (Programming / main tracks) have died (cannot drive any loco).
So, to summarize: if you have a CS2, keep it, excellent unit, but I would not advise to buy one unless at 25% of a CS3 price or below
Also avoid purchasing early CS2: 60213 and early 60214 (no 5A capability but only 3A capability, no galvanic separation causing may failures).
Offline Eurobahnfan
#5 Posted : 01 October 2022 03:06:48(UTC)
Eurobahnfan
Thanks Jean! I have a CS3 on order… happy to know I made a good choice 😁
thanks 2 users liked this useful post by Eurobahnfan
Offline mrunix
#6 Posted : 01 October 2022 07:50:51(UTC)
mrunix
Thanks alot for all input, its ofcourse tempting when price is half of CS3 but I belive you all that CS3 is the best of these 2.
CS3 is also very old 6-7 years if I understand it right, should not a CS4 arrive soon, no rumours out of that?
Offline mrunix
#7 Posted : 01 October 2022 07:51:52(UTC)
mrunix
Did you order CS3 or the CS3+?
Offline STE-BM
#8 Posted : 01 October 2022 11:15:33(UTC)
STE-BM
Hi MrUnix,
Not sure where you are based but in case BesserePreise ships to your country it’s worth you checking their site to buy a CS.
The CS3+ is 21% off from that store.
CS3 at 592€.
Otherwise I do agree with you that based on the retail price the CS3/CS3+ are very expensive and a CS2 might look like an alternative.
I’ve been looking at prices recently and theirs were substantially better than other well knows sellers and made a cs3+ more palatable.
thanks 1 user liked this useful post by STE-BM
Offline mrunix
#9 Posted : 01 October 2022 13:11:30(UTC)
mrunix
Originally Posted by: STE-BM Go to Quoted Post
Hi MrUnix,
CS3 at 592€.
Yes they had good prices, 5% off compared to Trainshop.se in Sweden where I am based.
I will give it a though.
edit. I checked other stuff tracks and turnabouts at BesserePreise and they have good prices, Thanks for the tip :)
Edited by user 01 October 2022 16:33:38(UTC)  | Reason: Not specified
#10 Posted : 01 October 2022 13:24:18(UTC)
No news nor much talk of a CS4. I think the CS3 is rather capable going forward, and with many users operating it via a web based route control or software like Rocrail they rarely need to touch it. It is contrlled by those, I think. Unless marklin decides a larger screen is in order, or they improve the "world of operation" cab driver graphics or other.
The Roco Z21's don't have screens, you use a tablet, phone app., or a p.c.'s screen. They have the best cab driver graphics.
Offline mrunix
#11 Posted : 01 October 2022 14:40:44(UTC)
mrunix
If using a system like Rocrail will it matter if I have a CS2 or CS3, I mean will something work better using CS3 or is it all up to Rocrail?
Edit. never mind the CS2 question as I see that the CS2 that was on sale was 60213:B which according to this thread means a very old CS2.
So its mearly a question of CS3 or CS3+, since I have a Mobilestation from the startup set and a CS3 Link 88 needs a PSU then I can resuse the one I have and could safe a lot of money if I understand it correctly?
Offline blid
#12 Posted : 01 October 2022 15:02:06(UTC)
blid
If you are going for computer control the CS3 is a very expensive way to go. However, I have not had a reason to investigate the market so I have no suggestions. Just as a possibly outdated example I know Littfinski, LDT, had a DiCoStation.
thanks 1 user liked this useful post by blid
#13 Posted : 01 October 2022 15:22:33(UTC)
All opinions are good. As a Rocrail user, yes to use the CS3 only as a conduit between your computer and your layout seems make little sense BUT the CS3 serves many other purposes:
- program the loco parameters
- program the sounds of the mSD2s and mSD3s
- to watch the current drain (and detect all abnormalties
- to collect all sensors and watch / simulate them
- and much more I forget
Besides, as I use it with a 60101, it delivers 5 A to my 32 locos permanently connected (No booster).So definitely I never regretted the CS3 I purchased.
Offline mrunix
#14 Posted : 01 October 2022 16:38:40(UTC)
mrunix
A PSU question, why do Märklin recommend the 60VA PSU for H0 instead if the 100VA, is it a sequrity issue when short circuits happends during derail or why?
c
#15 Posted : 01 October 2022 16:49:22(UTC)
My cristal ball is as good as yours but:
The CS2 60213 was launched in 2008 and lasted until 2016 (8 years)
The CS3 / CS3+ were launched in 2016 and could last until 2024 (8 years)
Yes there are influencing factors (availability of components, etc but:
- Chances are Märklin is already working on a new generation
- likely date 2024
- warning signs of new generation released soon: when the CS3 will be included in mega start sets
Just my thoughts
Offline blid
#16 Posted : 01 October 2022 16:51:42(UTC)
blid
Yes, you are right. But if you always have a lot of consumers and a current draw close to max (5 amp) the power might be turned off before some serious dammage. According to Marklin the 60101 is for OneGauge.
Offline Eurobahnfan
#17 Posted : 01 October 2022 17:03:03(UTC)
Eurobahnfan
I’m not too concerned about a CS4 potentially coming along soon… my IPad is 8 years old and still going strong 😉. Even if I build a newer, larger layout, I think the CS3 will serve my needs for many years. BTW: I chose the CS3 rather than the CS3+ as it seemed a better fit.
#18 Posted : 01 October 2022 17:19:36(UTC)
Yes, yes. This topic has been covered to death already:
- yes Märklin advises to set to 60W (3A) all boosters
- yes, functioning with 5 A is very safe even for HO (Some competitors to Märklin offers 8 A modules)
BUT
- yes the answer-back signal from MFX locos is weaker because on an increased number of Märklin locos on the same circuit. No big deal, you may have to register new locos on the programming track. This is no problem.
- yes many signals cannot stand 5 A but EVEN 3 A are too much (Märklin dixit, read the Märklin documentation). I use NO insulated sections thanks to Rocrail.
- yes Märklin prefers selling more boosters (60175) and their power supply (60041)
- yes Märklin prefers not to be involved with any {legal} side effects on high currents (5A) on flimsy wirings on some layouts
I am using a 60101 power supply since 10 years and never observed anything adverse on tracks, wheels
It has to be said that the overcurrent detection is working just great never leaving the high currents destroy anything
Just my 2 cents worth
PS I am a French Engineer in Linear and digital electronics, having exported my designs to the USA, Canada, China, etc
Offline Copenhagen
#19 Posted : 01 October 2022 17:19:45(UTC)
Copenhagen
If it hasn't been mentioned; if you get a CS3 your Mobile Station can be connected to it as a slave.
Online kiwiAlan
#20 Posted : 01 October 2022 17:32:23(UTC)
The cs3 definitely has a better processor - it is a quad core processor where the cs2 has a single core processor. This is a major reason why the cs3 is so much faster than a cs2.
Offline mvd71
#21 Posted : 03 October 2022 06:41:04(UTC)
I’ve had all the versions of central station, and if something happened to my current cs3, I think I would upgrade to a 6021
Offline Eurobahnfan
#22 Posted : 03 October 2022 07:13:26(UTC)
Eurobahnfan
I still have my 6021… and don’t intend to part with it. When all else fails, I know it will still be there for me 😉. (Looking forward to my CS3 just the same)
#23 Posted : 03 October 2022 16:31:59(UTC)
I still have my 6021 as well! The large white transformer I got with it (no speed knob) that I though had fried wasn't. I opened it up to test the resistors, and fuse, and a wire to the board had worked loose from it's solder point. Easy fix.
This page was generated in 1.028 seconds.
