Offline nelson77
#1 Posted : 17 June 2022 18:06:58(UTC)
nelson77
I had to leave my layout Marklin Ho digital CS2 in 2016. On my return just found out all was erased from my main CS2. My question is how to upgrade my CS2?
There are so many CS2 uploads how do I select the correct one? Also should I have yo upgrade all the upgrades?
Thanks in advance,
Nelson
#2 Posted : 17 June 2022 18:53:12(UTC)
Thanks in advance,
Nelson
The best way is to connect it to the internet and let it talk to Marklin. It will sort out what upgrades are required by itself.
If it is that long since you last used/updated it then there may well be an intermediate upgrade it needs to do before the latest updates can be loaded. If you allow it to talk to Marklin it will sort all this out itself.
It doesn't need to be connected to the layout while doing the update, so you can put it and the power supply beside your router, hook up an internet cable, and then follow the instructions in the manual to enable the update from the internet.
Offline nelson77
#3 Posted : 17 June 2022 20:43:34(UTC)
nelson77
Thank you kiwiAlan for the information. That is great advice. I assume I do the same for the slave CS2?
Nelson
#4 Posted : 17 June 2022 23:05:37(UTC)
Nelson
Yes, it will need the same treatment, you can't transfer between them.
This page was generated in 0.355 seconds.
