Offline fossie
#1 Posted : 28 November 2021 10:53:09(UTC)
fossie
Dear All
I have a couple of old Marklin M track 5117 points that I want to digitise by a Marklin k83 decoder and incorporate them into my digital layout running with Win digipet.
I want to replace the bulb in the lantern on each point with an Led bulb as they draw to much current. Does anyone know where I can get the Led bulbs or create a diy solution with some other type of Led bulbs from ebay etc.
Many thanks
Andy
#2 Posted : 28 November 2021 11:48:17(UTC)
There was a fellow selling them on eBay a couple of years ago.. I still have some, but I can't seem to find them on eBay any more.. You could make them but you would need to be soldering a tiny LED to a sMD resistor small enough to stuff inside the bulb base... too hard for me to do..
I don't use the Marklin K83, I use the Viessmann 5211 (I think is the correct number), which allows the use of an external feed.. Have a read of this article from AJC Kids -> https://ajckids.com/blog...211-turnout-decoder-k-83 . Also I connect the turnouts, signals and K84 modules to their own booster so that the track current is not wasted on accessories..
#3 Posted : 29 November 2021 00:13:55(UTC)
eBay seller tufftuffde (Daniel is his name) sells the Marklin 600000 bulb led replacements.
https://www.ebay.de/itm/...0f77f:g:xFYAAOSwZkJURibV
Offline franciscohg
#4 Posted : 29 November 2021 03:17:41(UTC)
franciscohg
Chile
The leds works fine. i use them in old signals.
In turnouts i have separate the feeding of the bulb from the feeding of the solenoid. This way i can lit them up or off and power trough a separate transformer so power consumption if of no interest.
#5 Posted : 29 November 2021 09:37:20(UTC)
Also here: BigGrin
https://www.conrad.com/p...te-ms4-19-v-1-pcs-497332
This page was generated in 0.530 seconds.
