Offline Drongo
#1 Posted : 18 September 2021 08:40:04(UTC)
Drongo
Does anyone know for sure how to isolate the tracks on a C track double slip. I'm using TraninController and I need to isolate the tracks so as to implement track occupancy. Do I cut all 4 track tabs, similar to a straight track where I cut both track tabs.
Greg
#2 Posted : 18 September 2021 10:21:02(UTC)
Seems I recall seeing an explanation with photos, but not sure where. Have you googled it?
Offline pederbc
#3 Posted : 18 September 2021 10:36:21(UTC)
pederbc
Hi Greg,
I also use TC and I don’t see the need for detection at switches. I use train lengths and set the lengths of each block. If a train doesn’t fit in a block, the route over the switch will not be released. I have never had any problem with this setup. I have used TC since version 5.
I use TC 9 gold. What version are you using?
Br, Peder
Offline Drongo
#4 Posted : 18 September 2021 12:48:47(UTC)
Drongo
Originally Posted by: pederbc Go to Quoted Post
Hi Greg,
Br, Peder
Hi Peder, I'm using version 9 and I've been using TC for over 5 years now, however this is the first time I've used double slips. I guess I'll have to experiment with the little red tabs and see if this helps or sacrifice one double slip.
Greg
#5 Posted : 18 September 2021 13:36:24(UTC)
Hi Greg
Rocrail user here. It is not so different from TC and does not need to perform such operations on switches and double slip.
Usually a simple detection just before the double slip and after is enough. Just a thought.
On my layout, there are many double slips, triple switches and regular switches. No need whatsoever
Here it is in operation
Offline pederbc
#6 Posted : 18 September 2021 15:23:43(UTC)
pederbc
On each block (usually tracks between 2 switches) i use 3 sensors, 1 on each trackpiece on the ends and 1 sensor on all the pieces between. So just as John describes, there’s a sensor on eack trackpiece connected to a switch (of any sort). I also make sure that I can detect each wheel on the train so I can detect lost cars. If you possibly run out of all luck there could be a small car lost right on the switch, but I have never been that unlucky😎(yet).
Peder
I use C-track and detect by isolating one of the rails. Checkout the ”diode trick” if you’re not familiar with it.
Offline Vaji2021
#7 Posted : 19 September 2021 05:40:15(UTC)
Vaji2021
Sri Lanka
Greg, I agree with Jean. If you are using a 24624, note that the mechanism is quite delicate and is easily damaged. It is best to avoid doing anything directly on the switch. Like Jean, I use contact track pieces on either side of switches when needed.
Vaji.
thanks 2 users liked this useful post by Vaji2021
Offline Drongo
#8 Posted : 20 September 2021 02:13:18(UTC)
Drongo
I think I have resolved the problem. I didn't touch the double slip - I added some short pieces viz. 24064's to each "leg" and I applied the red tabs to these short pieces, and so far it seems to be working.
Thank you for your assistance.
Greg
thanks 2 users liked this useful post by Drongo
Offline RedAggl
#9 Posted : 06 October 2021 09:20:33(UTC)
RedAggl
On each block (usually tracks between 2 switches) i use 3 sensors, 1 on each trackpiece on the ends and 1 sensor on all the pieces between. So just as John describes, there’s a sensor on eack trackpiece connected to a switch (of any sort). I also make sure that I can detect each wheel on the train so I can detect lost cars. If you possibly run out of all luck there could be a small car lost right on the switch, but I have never been that unlucky😎(yet). mcdvoice
Peder
This page was generated in 0.619 seconds.
