Offline Puttputtmaru
#1 Posted : 17 May 2021 18:35:06(UTC)
Puttputtmaru
I am a bit confused as to which one do I need? Some help would be appreciated (some are bigger bottles of course)
00905, 00910, 00911, 02420 are thay all interchangeable with no problems? If you have other alternatives I am open too.
#2 Posted : 17 May 2021 18:52:36(UTC)
#3 Posted : 17 May 2021 19:47:15(UTC)
It's pretty much the same. Kerosene. Recommended by the Marklin dudes.
#4 Posted : 17 May 2021 20:06:43(UTC)
Puttputtmaru
Thank you, I ordered the Blue juice.
Funny how on the Canadian Amazon site buying one bottle is 22$ and buying two is 21$ For BOTH (shipping free with Prime).
I got twoCool
thanks 3 users liked this useful post by Puttputtmaru
Offline skeeterbuck
#5 Posted : 18 May 2021 12:12:49(UTC)
skeeterbuck
I've always used the actual Seuthe fluid. When I've tried other types they either didn't work as well (less smoke output) or tended to clog up the small tube on the Type 10 units. I get the 150ml size and it last a long time.
I'd be interested in learning the results from using the Blue Juice or kerosene as to smoke output and clogging issues.
Chuck
thanks 1 user liked this useful post by skeeterbuck
#6 Posted : 18 May 2021 13:37:29(UTC)
I got a gallon of karosene at Home Depot for about $13. I keep it in a dark place so tjhe light doesn't deterorate it. It works good, even in the narrower 7227 unit.
#7 Posted : 18 May 2021 14:07:30(UTC)
I have been using Blue Juice for over a decade without problems.
This page was generated in 0.499 seconds.
