Offline luckas
#1 Posted : 12 May 2021 10:09:04(UTC)
luckas
Greetings,
When adding an additional S88 to a Link S88 via bus1 (or bus2) RJ45, should it just appear in the CS3 system devices, or is there something else that needs to be done? There's nothing new appearing in my CS3 system devices.
Paul
thanks 1 user liked this useful post by luckas
#2 Posted : 12 May 2021 12:52:30(UTC)
Yes, refer to the webinar #2 I think.
#3 Posted : 13 May 2021 00:26:46(UTC)
No, no S88 (6088,60880,60881,60882) "appears" anywhere - automatically or manually.
In the first instance you need to define the host (CS, L88) of the number of S88s on each bus so it can be "prepared" to use them.
But the only indication you have that a S88 exists is when you define a sensor port (by addressing is ID,bus,module,port) and seeing if it turns Red (not found) instead of White/Yellow.
This page was generated in 0.364 seconds.
