Offline zoooctan
#1 Posted : 04 May 2021 14:40:11(UTC)
zoooctan
Singapore
Sorry for maybe creating multiple threads...but I wanted to title this correctly. Inspired by my research on DC transformers and asking about Gaugemaster on the other thread, I was inspired to just wire up my Marklin transformer to measure it's voltage. I know it should be rated at 10v maximum but can someone please tell me if I'm measuring this wrong as the maximum output seems to be closer to 16v?
Is this correct?
Online H0
#2 Posted : 04 May 2021 14:52:50(UTC)
Maybe the results will be more meaningful if you measure while a loco is running.
Offline Poor Skeleton
#3 Posted : 04 May 2021 22:14:10(UTC)
Poor Skeleton
Is this correct?
Without a load the "leakage" through the controller can cause the output to be higher than it should be. Once loaded (i.e. with a locomotive connected) the voltage will come down to a more reasonable level.
Chris
Offline zoooctan
#4 Posted : 05 May 2021 04:19:33(UTC)
zoooctan
Singapore
Thank you for the response. I tried this again with the advice above, and the results did indeed come down. So thank you to everyone. I think I missed a step as I was watching a rather comprehensive video on Youtube on testing voltage ratings using Gaugemaster and Morley. I really thought that the output would be measured directly.
This page was generated in 0.471 seconds.
