Offline Marklinisten
#1 Posted : 09 April 2021 11:03:02(UTC)
Marklinisten
Just a question before finalizing some tracks (C-track)
If I want a detection of a train presence entering a side track which ends which ends with bumper I would need a contact track just at the entry right?
A "homemade" contact track would do just fine I guess.
Do I still cut the ground at both ends of my "homemade" track and do I need to put the small red insulation "thingys" on both ends?
How about power feed?
I guess that I need an additional one either on the contact track or after it.
The intention is to use S88 for train detection.
Btw, Is it always necessary to use the L88 between the S88 and the CS2?
Thanks for your patience with an happy amateur like myself!
Roger
thanks 1 user liked this useful post by Marklinisten
Online PeFu
#2 Posted : 09 April 2021 11:35:09(UTC)
PeFu
Depending on what you want to achieve, the length of your side track, and the length of the trains you intend to put there. If train speed is slow, it could be better to have only a very short contact track close to the bumber, in order to indicate both ”stop” and ”occupied”.
Online MHJ87
#3 Posted : 10 April 2021 05:02:22(UTC)
MHJ87
Hi Roger.
I agree upi depends on what you want to achieve.
For what it is worth I have gone for the option of one at the entrance and one near the bumper because I think is provides more flexibility. You can slow the train to a walk on entry and then the contact track near the bumper will tell the system when to stop the train.
Unfortunately I cannot help with the CS2 question as I have a CS3+
Michael
#4 Posted : 10 April 2021 10:13:28(UTC)
Marklinisten
The only purpose of the contact track would be an indication on CS2 that a train (mostly short railcars) has entered the side track.
The train(s) would be completely manually manoeuvred from CS2 I.E no automation, starting, stopping or slow down.
I good idea might be to secure a possible future with TC or similar maybe.
But I guess one at the beginning of the track and one near the bumper will do fine then?
Does anyone have a nice "how to do and how to think" manual or knows a web page in regards to contact tracks and train indication?
Roger
Offline Danlake
#5 Posted : 10 April 2021 11:52:18(UTC)
Danlake
Hi there,
You will probably find most resources in regards to contract tracks on this website. See e.g.
https://www.marklin-user...locks-and-contact-tracks
https://www.marklin-user...-homemade--Contact-Track
To answer your specific questions:
Yes you need to isolate the rail in both ends, by cutting the taps underneath the C track and install the red isolation plastic. If you have a multi meter suggest you always test the rail is proper isolated. Also some c tracks rails will touch each other so you may have to use a file to ensure there is a gap between the actual rail as well.
The power will still flow through the track through the Center rail and the other ground return rail that hasn’t been isolated. So in theory you don’t need to install a feeder after your contact track on the siding.
In general I would recommend to spend the time and effort upfront installing enough contact tracks to ensure you can have some basic automation. So on a siding I would install one just after the turnout to e.g. slow down the loco and then one just before the bumper to stop the train. On a long siding I would have 3 pieces with one in the middle to e.g. set the loco to crawl speed.
It’s super easy to make C track occupancy sections, so if you are thinking on a further computer software automation just go ahead and plan enough sections BigGrin
Best Regards
Lasse
#6 Posted : 10 April 2021 14:35:13(UTC)
Roger you ask many questions and here are some of my answers
Do I still need the ground? In theory no if you cut all your contacts on the same side of the track
Do I still cut the ground at both ends of my "homemade" track and do I need to put the small red insulation "thingys" on both ends? You need to make sure that all C track sections have their bridges cut and you use either the small red insulating shoes or you cut the rail (and remove thoroughly all metal dust) If you also cut the bridge on the buffer then you don't need another cut /insulation shoes.
Where to have the contact tracks? If you drive manually, the contact track will serve little purpose (you do what you want as it is only for signalling purposes
In automatic mode (I use Rocrail), I use 2 sections: one short near the switch and a long one for the entire storage zone.
The result is this when uncoupling
and this for getting back the wagons
Why? because the first short detection allows to detect the loco when it comes back to collect the wagons) and the long one to detect that wagons are stored there.
Note: for passenger cars storage I use the same principle but only the main detection is on 20 cm before the buffer to slow down the consist
Is it always necessary to use the L88 between the S88 and the CS2? No, if you have old modules (6088, 60880) you can connect them by the flat cable directly using the connector under the CS2. There is a constrain: electrical noise limiting the total flat cable length to 2 m and the chain arrangement of M88 modules.
With a link88 you may have 3 buses so 3 directions to distribute your new L88 modules. The last advantage is when converting to a CS3 then the change is painless. In my case I had to change the addresses of the M88 modules to be connected to the BUS 3 of the Link88 but before I had both a Link88 (60883) with 60881 modules and old S88 modules connected with the connector under the CS2.
Note: all the videos above show leaving and picking cars / wagons in totally automatic action.
#7 Posted : 11 April 2021 14:11:12(UTC)
Marklinisten
Thanks for all your answers!
Cheers!
Roger
Märklin Contact Track (Digital)
by geir 20/03/2024 17:23:47(UTC)
Question about contact tracks (General MRR)
by Chris6382chris 09/09/2023 00:04:09(UTC)
Marklin Circuit and contact tracks (Digital)
by Luna 25/07/2023 05:37:21(UTC)
whistle from contact track (Digital)
by heinrichhess 30/05/2023 21:45:53(UTC)
Contact track K-2295 - C-24995 and various M-tracks (General MRR)
by auntmartha 24/05/2023 18:10:29(UTC)
contact tracks in hidden yards (Digital)
by Don Morris 24/03/2023 01:56:40(UTC)
by Thewolf 12/12/2022 02:50:23(UTC)
Can Digital Bahn GleisReporter C track connections/contact track (Digital)
by einotuominen 06/10/2022 10:49:05(UTC)
Pre connecting contact tracks on MS2 before changing to CS3 (Model railroad wiring)
by einotuominen 19/09/2022 06:14:46(UTC)
7286 Turntable activates empty shed contact tracks. (H0-scale)
by luckas 15/06/2022 11:02:54(UTC)
Marklin Contact track 24995 (Digital)
by Carlos 13/05/2022 16:35:20(UTC)
M contact tracks (H0-scale)
by BenP 27/04/2022 15:47:03(UTC)
c-track contact track ends touching (H0-scale)
by trainbuff 10/04/2022 00:32:52(UTC)
Contact track on K-track turnout? (H0-scale)
by DanK 03/04/2022 23:59:17(UTC)
CS3+ S88 contact track event (Digital)
by marklinist5999 03/08/2021 15:11:05(UTC)
Contact Tracks for K track (H0-scale)
by Harvey 14/03/2021 01:34:22(UTC)
Contact Track with Märklin M-track (H0-scale)
by amartinezv 13/03/2021 09:57:37(UTC)
Contact Track, M-Track and S88 (Digital)
by Harvey 15/12/2020 01:19:00(UTC)
16 Contact tracks and I don't know what to do with them (Digital)
by oranda 18/08/2020 15:08:55(UTC)
CS3 contact track icon (Digital)
by QQQ1970 27/04/2020 01:03:23(UTC)
Dead spots on C contact tracks (General MRR)
by obb_taurus 12/01/2020 19:41:32(UTC)
M Track analogue contact track5146 (General MRR)
by David240945 10/01/2020 23:22:57(UTC)
Purpose and use of Contact Track 5115 (H0-scale)
by sharples 07/08/2019 03:44:38(UTC)
Contact Track with C Tracks and MS as moving (Digital)
by federicofreundt 16/03/2019 22:26:46(UTC)
Zener diode and contact track (Digital)
by phyan 19/02/2019 16:48:21(UTC)
contact track 5146 connected to two signals (Model railroad wiring)
by stockerta 14/10/2018 09:38:44(UTC)
Make your own Märklin C-track Contact Track (General MRR)
by Thewolf 06/03/2018 17:55:40(UTC)
How many solenoid devices can one contact track drive? (Model railroad wiring)
by asp1880 05/09/2017 20:01:05(UTC)
Märklin 24922 part of contact track/block (H0-scale)
by dennisb 21/10/2016 14:43:19(UTC)
Contact track length in shadow yard (Digital)
by pschloes 17/03/2016 00:11:15(UTC)
Placement of contact tracks with windigipet software (Model railroad software)
by marklin61 30/01/2016 23:28:11(UTC)
Circuit and contact tracks C purposes? (Digital)
by federicofreundt 17/10/2015 02:10:25(UTC)
Modules for K track contact tracks (Digital)
by PeFu 03/04/2015 20:52:06(UTC)
Contact Tracks - Question (H0-scale)
by SteamNut 16/12/2014 17:26:46(UTC)
CS2 doesn't show signal from contact track (Digital)
by BrianM 27/08/2014 21:00:26(UTC)
by greytag 21/02/2014 20:28:11(UTC)
how to use track blocks and contact tracks (Digital)
by Laxman 20/02/2014 07:22:59(UTC)
Automatic Station with Contact Tracks (Track plans)
by Laxman 11/02/2014 01:03:02(UTC)
Contact Track, Switching Track or Reed Switch (Digital)
by PMPeter 09/11/2013 22:38:45(UTC)
Basic Contact track wiring question (Model railroad wiring)
by Mike M 27/08/2013 18:09:26(UTC)
Marklin Switch Track and Marklin Contact Track (Model railroad wiring)
by kumarvartak 16/06/2013 10:50:58(UTC)
C-Track "blocks" / contact tracks (Digital)
by pmgsr 13/02/2013 23:46:12(UTC)
hints for using circuit track 24994 and contact track 24995 (Digital)
by sikardon 11/08/2012 16:08:35(UTC)
Contact tracks, S88, Memory on CS2 (Digital)
by fhp2 29/02/2012 22:11:33(UTC)
Nielsenr - Contact tracks in Braking Area (Digital)
by Nielsenr 30/08/2011 05:37:02(UTC)
C-Track switching contact track 24994 (H0-scale)
by river6109 04/05/2011 11:17:59(UTC)
DIY (homemade) Contact Track (H0-scale)
by JD 30/11/2009 19:32:24(UTC)
Contact track sensing (Digital)
by perz 22/02/2009 19:21:00(UTC)
Contact tracks problem/questions (Digital)
by WelshMatt 29/01/2009 12:48:53(UTC)
Marklin Metal Contact Track Section (H0-scale)
by aos 28/12/2008 22:16:13(UTC)
This page was generated in 0.623 seconds.
