Offline thothorn
#1 Posted : 03 January 2021 18:25:49(UTC)
thothorn
Dear all,
As a father of two, my own experience with H0 rails dates back 30 yrs, but
now I can't keep my hands off any longer.
My daughter and I spent the last days designing a L-layout fitting a
relatively small corner in her room. The curve radii seem to be rather
small, and I wonder if this will work at all. There are three levels, at 0,
4 and 8 cm, and maybe the elevation is too ambitious as well?
We would appreciate any expert comments on our layout sketch, which
can be inspected in PDF form
http://user.math.uzh.ch/hothorn/docs/H0_layout.pdf
and in XtrkCAD source form
http://user.math.uzh.ch/hothorn/docs/H0_layout.xtc
Many thanks,
Torsten
Offline scraigen
#2 Posted : 05 January 2021 15:21:55(UTC)
scraigen
Hi Torsten,
I'm struggling to understand which bits of your plan are at which heights?
Stu
Must build something
Offline scraigen
#3 Posted : 05 January 2021 15:53:07(UTC)
scraigen
Yes I think you have just enough track to make the gradients, I usually plan on 12 to 15 pieces of R1 curve or 180mm straight for a ramp before crossing over/under another track.
So if I understand correctly then the middle right of your plan is where everything crosses over so one of those is 0 and the track going over is +8cm and then everything else is ramping between those two points, which would make the top left sticky out bit of the L about +4cm.
Offline thothorn
#4 Posted : 05 January 2021 19:14:13(UTC)
thothorn
OK, thanks!
Yes, exactly. It would have been easier with a bit more space in x-direction (only 90cm width) but I'm glad it seems doable. Will be off to the local dealer, then ;-)
Thanks a lot!
Torsten
thanks 2 users liked this useful post by thothorn
This page was generated in 0.333 seconds.
