Offline BobG100
#1 Posted : 05 December 2020 16:20:52(UTC)
BobG100
In the process of using SCARM to lay out various Trix HO C-track section configurations I've sometimes seen two yellow arrowheads appear at a
track interface instead of the standard all-is-correct red and green markers present just before the sections "snap" together. Fig. 1 illustrates an
example of such an apparent misalignment- -in this case it occurs where the #62094 straight track joins the #62612 turnout. Fig. 2 shows the color
arrowheads I observed as I tried to connect the track sections involved.
Do the yellow arrowheads indicate an actual track misalignment or are these markers just an artifact of the software?
BobG100
Offline Legless
#2 Posted : 06 December 2020 08:06:20(UTC)
Legless
Hi Bob,
when there is more than one connection, this happens, but don’t worry, it still works out fine.
Legless
Offline BobG100
#3 Posted : 15 December 2020 06:51:00(UTC)
BobG100
Thank you, Mike. It's a great relief knowing that many of the trial track arrangements I simulated with SCARM can be assembled without certain sections having to be forced together and possibly distorted. Now, finally, I can go ahead and order track and start layout construction.
BobG100
thanks 1 user liked this useful post by BobG100
This page was generated in 0.320 seconds.
