Offline johnmarklin
#1 Posted : 29 November 2020 12:49:47(UTC)
johnmarklin
Ireland
Good morning fellow enthusiasts.
I am looking for your assistance and advice. I recently bought a Marklin locomotive fitted with a Loksound 5 decoder. When I put the loco on the track it was detected by the CS2 as MFX but the locomotive would not work. I replaced the decoder and all worked perfectly. I put the Loksound aside until I had more time to examine and test it. I used an ESU decoder tester which indicates that the decoder is working. I installed it in another locomotive, again the same issue. The CS2 recognises loco as MFX but the loco does not function. Out of curiosity I tried the loco with an Intellibox. The Intellibox read the decoder and the loco drives forward and reverse switches lights. I have not had time to check other functions.
Can anyone explain to me why the CS2 recognises the loco but will not operate it and why the Intellibox (older version) recognises the decoder and will operate the loco normally?
Looking forward to your suggestions.
Thank you,
#2 Posted : 29 November 2020 15:17:14(UTC)
Just a wild guess...
Does the CS2 have the latest firmware?
I remember that the MS2 had a buggy mfx implementation and required a firmware update to work with ESU V 4 decoders.
Offline applor
#3 Posted : 29 November 2020 23:55:51(UTC)
applor
Perhaps an issue with protocol hierarchy on the LS5.
You could try changing the CV responsible for protocol by disabling everything except MFX and see if that helps. Alternatively you can disable MFX and test it as DCC.
Offline johnmarklin
#4 Posted : 30 November 2020 00:09:42(UTC)
johnmarklin
Ireland
Thank you to all for your suggestions. The CS2 is on latest software update. I will work on the CVs tomorrow and report back.
thanks 1 user liked this useful post by johnmarklin
This page was generated in 0.356 seconds.
