Offline applor
#1 Posted : 20 November 2020 02:54:59(UTC)
applor
Can anyone tell me the wiring colour code for Marklin 1 gauge with a hall sensor for wheel chuff sync? I have yet to find it, at least compared to the colours used in this model.
The model 55913 which is a Prussian T9.3 has 3 wires:
brown/red
brown/white
brown/green
Unfortunately I can barely see the 3 pin hall sensor but cannot see the wires attached since it is buried in the body.
I figured red was +, white was gnd and green was input but that has not worked, hopefully I have not damaged it.
Offline applor
#2 Posted : 20 November 2020 04:37:42(UTC)
applor
Perhaps more importantly, has anyone used a Loksound XL decoder with a 1 gauge Telex function?
I've tried setting it to coupler but not getting anything, unless I have wired it wrong...
Offline applor
#3 Posted : 09 December 2020 11:55:12(UTC)
applor
Well I got the Telex working OK after a long struggle.
This just leaves the wheel sensor again but removing the wheel plate has exposed the wiring (and a small PCB) so I have more to work with now.
Can anyone identify this sensor and components and the wiring for use with a LS?
Offline applor
#4 Posted : 10 December 2020 02:31:24(UTC)
applor
Looks like brown/white is input and brown/green is ground (brown/red remains V+) but it still does not work so it is either not a hall sensor or it is damaged.
#5 Posted : 10 December 2020 19:19:14(UTC)
I have a few of this model; but I'm not home right now, so I can't really help............ Blushing
Offline applor
#6 Posted : 10 December 2020 22:17:45(UTC)
applor
It's OK I received a response on Stummi forums stating that the hall sensor does not work with a replacement decoder but can be replaced with a TLE4905 which does work.
This page was generated in 0.282 seconds.
