Offline Roman
#1 Posted : 21 October 2020 20:43:01(UTC)
Roman
Can the early F 800 BR01, .1 and .2 with a broken smoke stack rim be replaced by the Ritter 3048 schornstein replacement? Thank you.
#2 Posted : 22 October 2020 17:03:02(UTC)
Hi Roman
I am pretty sure it can.
IMO it is a matter of using a proper size drill (check with a caliper when you receive the Ritter part) and using a sensitive drill (Mounted on a column for precision drilling) while the loco body is well fixed.
This page was generated in 0.293 seconds.
