Offline franciscohg
#1 Posted : 15 October 2020 16:34:56(UTC)
franciscohg
Chile
Hi all
In another group i stumble across some guys who use a booster to protect the command station. They connect the layout to the booster not using the command station to power the layout.
I havent heard of that before, has some logic, but, is really necesary this kind of protection today with almost all stations having galvanic isolation?
Any thoughts?
#2 Posted : 15 October 2020 18:28:37(UTC)
Galvanic isolation is not the point AIUI. The boosters also need galvanic isolation.
If a short circuit of any kind kills the booster, then it is cheaper to replace a "booster only" device instead of a "controller with booster" device. However you pay more to get started.
External power sources can kill a booster - the internal overload protection of the booster will not detect this.
If the booster is not connected to the overload detection of the controller, then you can still switch turnouts when the track power is off, provided you have a separate booster for turnouts. This can be a big advantage.
Offline franciscohg
#3 Posted : 15 October 2020 19:25:17(UTC)
franciscohg
Chile
Hello Tom
My doubt finally is if a short circuit in the layout can really kill a command station with galvanic isolation.
If so, to feed the layout trough a booster seems not a bad idea at all.
I had a 60214 fried years ago, but was an early unit, with no galvanic isolation
#4 Posted : 16 October 2020 02:07:09(UTC)
I would not be focusing on a "short" only.
From my experience the thing most likely to kill the output drivers of a 6021, 60212, 60213 (haven't experienced a 60216) is the miswiring of the layout - typically the Yellow accessory power being connected to the Red Track feed.
I , also, back the idea of not using the Controller to do the track work once your layout gets to the stage of needing a bootser.
thanks 5 users liked this useful post by clapcott
#5 Posted : 16 October 2020 15:33:43(UTC)
Hello Tom
Galvanic isolation has nothing to do with this, it is purely about destroying the outputs from the control unit with a short circuit (or more likely a low impedance circuit that doesn't cause the overload protection to kick in). The continuous current draw at a level that is causing the drivers to have a lot of voltage across them and therefore dissipate a lot of heat causes them to burn out.
It is easy to get to this stage with a derailment (say on a point) where the combined resistance of the feeder wires and the imperfect connection of the wheels or whatever that is causing the short will limit the current below the overload current that would cut out the output stage, but the output drivers cannot maintain the full output voltage, but in trying to do so will burn out. so as mentioned, some people prefer to use a booster as a sacrificial device to keep the control unit intact.
Offline rrf
#6 Posted : 16 October 2020 22:11:34(UTC)
rrf
<Stuff Deleted>
If I decide to make the investment to implement one or more booster sections in an effort to protect my Central Station, can I still use the CS3 to control my M83s, M84s, S88s, signals and breaking modules without losing the benefit provided by feeding all of my tracks and trains with boosters? Or would they require their own booster to protect the CS? Note: I already use external power supplies for all of my blocks of M83s and M84s.
Rob
Mackenrode Wende Bahn
#7 Posted : 16 October 2020 22:45:51(UTC)
This is how I've wired my layout - it is feed from two boosters but not the CS2 controller. It's cheaper to replace a booster than it is a controller.
You can connect whatever you like to the CS3's track output as long as you follow the rules around only having one device with no galvanic isolation providing track power - the CS3 does not have galvanic isolation, the CS3+ does (a really daft decision by Marklin IMHO). But doing so kind of negates the reason for not using the controller's track output in the first place.
Offline Henrik Schütz
#8 Posted : 16 October 2020 23:41:38(UTC)
Henrik Schütz
My CS3 has bern back to the factory for one year after it stopped deliver power to the track after a shortcut, every thing else worked.
I will absolutely run it with a booster for feeding the teacks once its repaired
Offline rrf
#9 Posted : 17 October 2020 00:21:46(UTC)
rrf
Hello again,
I should have been more precise ... I actually have a CS3+ and so don't have a Link-88 with it's own power supply. My S88s plug directly into the CS3 plus's RJ45 port.
So my question needs to be re-framed: Is there any protective value for my CS3+ if I isolate my M83s, M84s and signals to a booster, in lieu of powering them directly from the Control Station? Since my M83s and M84s all have their own power supplies, the only thing drawing power from the CS3+ should be the S88s and the handful of signals that have built in decoders.
Thanks and sorry for the confusion,
Rob
#10 Posted : 19 October 2020 20:28:37(UTC)
That is the approach I'm likely to take:
1) Power all track sections via boosters
2) Use CS digital power to feed decoders (M8x or embedded) and S88 modules.
But I imagine things are also often driven by the needs of the layout. If your layout is physically distributed over a long stretch of distance, it may make more sense to use the CS power output to feed a defined power district for cable running reasons, maybe pick on without switches in it so complex/problematic derails are less likely.
Offline rrf
#11 Posted : 20 October 2020 13:32:20(UTC)
rrf
<Stuff Deleted>
Thank you for your response Minok.
As I transition from last RR build season's Tisch Bahn of "Test Ovals" to the first phase(s) of a permeant layout, I will follow everyone's advice and plan for the following:
  • Start with a single Booster to power my track and control my M83s and M84s.
  • Other than the booster, the only components connected to my CS3+ will be the S88s.
  • Each block of M83s and M84s will receive their own power supply.
  • I will provide independent digital feeds for each M83 / M84 block, so that in the future they can be moved to new booster regions.
  • As the layout grows, I will add a terminal and additional boosters as needed.
Since I've built modular layout furniture (in anticipation of room and or house moves), it should not cause a huge amount of pain to add the new power regions. I do have one important question though ... should I keep a common ground ("O" / Brown) across the CS3+ and all of the booster regions? My thought is yes. But I remember reading a recent post suggesting that this is not a good practice for very large layouts.
Thank you everyone for bringing up this very important topic at an extremely timely moment, for my layout's final design.
Rob
This page was generated in 0.800 seconds.
