Offline patnaik
#1 Posted : 24 August 2020 20:54:43(UTC)
patnaik
I just purchased a used Marklin 37649 - Diesel Hydraulic Switch Engine BR 360. This comes with C90 digital decoder and TELEX couplers. It did not come with box or manual. I control my layout with an old Intellibox. The lok runs nicely and I am able to turn the lights on/off. However, I was not able to activate the TELEX couplers when I turn on any/all of functions F1-F4. Upon opening the lok, everything looks perfect and there is a brown/green striped wire and a black wire leading to the TELEX coils. Is there a trick I am missing?
Please forgive me if I have posted incorrectly; this is my first post on this forum.
#2 Posted : 24 August 2020 21:07:35(UTC)
What MM mode is the IB set up to use?
You will need the MM2 mode to use more than F0 which turns on the lights.
Offline patnaik
#3 Posted : 24 August 2020 21:51:38(UTC)
patnaik
It is set to Moto. New. for address 60.
#4 Posted : 24 August 2020 23:43:20(UTC)
Have you tried f5 through f8 ?
Offline patnaik
#5 Posted : 24 August 2020 23:53:58(UTC)
patnaik
No, I did not. However, I did find two problems after poking around with a meter:
1) There was no connection between the decoder brown/green wire and the TELEX coils (a solder bridge was absent). This was trivially fixed. Now I am able to activate the TELEX with F1
2) Only one TELEX coil is functional Mad A check with a meter shows open circuit across the coil leads. Need a new one. Anyone know of a source for parts in US? Google turned up nothing useful. Thanks!
thanks 1 user liked this useful post by patnaik
Offline TEEWolf
#6 Posted : 25 August 2020 00:27:32(UTC)
Here is a PDF table from Maerklin listing the major technical informations for your loco 37649.
https://www.maerklin.de/...ok-Datenbank-2006-12.pdf
The Telex coupler function is for a Maerklin controller on key F2. The rest should be in your IB manual.
Offline patnaik
#7 Posted : 25 August 2020 01:00:32(UTC)
patnaik
Thanks! You are correct, it was F2, not F1. That is a most useful document.
Online mvd71
#8 Posted : 25 August 2020 08:43:13(UTC)
Those coils for the telex usually come up on eBay.de
This page was generated in 0.419 seconds.
