#1 Posted : 26 May 2016 12:23:34(UTC)
Hi, this is my second 3029 digital conversion, the first one was sold und this one will come onto the market soon.
here are the improvements:
1.) 5 pole high efficiency motor
2.) 2 ball bearings (front and rear)
3.) 3 led's front, warm white low energy light
4.) 3 led's rear, warm white low energy light (2 led's consist of white and red led's, upper light white led
5.) 2 led's rear red marker lights low energy light, these leds are combined white and red led's at the lower level
6.) window inserts
7.) front and rear couplings shafts
8.) Telex coupling rear with pulse timing
9.) ESU lokpilot V4
to fit the led's in the back of the loco some drilling had to be done to insert the leds within the loco frame., a small circuitboard was fitted on top of the permanent magnet for the upper warm white led. ummy lights had to be drilled through
3 holes had to be drilled into the front 3 dummy lights and 3 led's had been fitted behind.
2 holes had to be drilled for the coupling shaft, some metal shaving had to be done so the coupling can move sideways.
a 5mm hole had to be drilled into the back of the motor frame to insert a 5mm ball bearing for the rear armature shaft
a 4mm hole had to be drilled into the brush plate for the front armature shaft.
an ESU 51968 adapter plate was fitted and there can be either another Telex coupling to be fitted, a cab light inserted.
1 x ESU lokpilot V 4
Edited by user 26 May 2016 16:15:41(UTC)  | Reason: Not specified
thanks 6 users liked this useful post by river6109
Offline Lebelge63
#2 Posted : 03 June 2020 20:02:55(UTC)
Lebelge63
6.) window inserts
9.) ESU lokpilot V4
Hi John and all ,
New on this forum,living in France mine English isn’t perfect...
I want take a new magnet motor in a 3029 locomotive.
You are talking about ball bearings can yoU give me more information (sizes...) and how to put them ?
Thanks a lot
Unidentified decoder in Märklin 3029 steam locomotive (Digital)
by Janne75 27/01/2022 14:51:43(UTC)
This page was generated in 0.250 seconds.
